Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
The program dial just keeps clicking around and leaving a full machine of water without finishing a cycle, My nearest town is Cannonvale or Airlie Beach Queensland
  • akornfeld Aug 08, 2010
    Don't think this is the problem, as it only seems to happen if I set a drying cycle to follow on from the wash cycle. Has happened before and sometimes just fixes itself. Other times have had to pay for it to be repaired but I don't know what the repairman did to fix it.
  • akornfeld Aug 09, 2010
    Thank you for your help, I will give it a try.
  • Ariston Tech... Master
  • 12,061 Answers
Check the pressure switch -the system that determines correct water level in the drum. Its a round item about 3 inches across with several wires connected, it sits under the top cover. Its an air operated switch which tells the machine water has reached the correct level. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage. Switch itself may be faulty but its more likely the pipe is blocked.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
http://www.manualsmania.com/download.php?link=df88da8e707ca1808d49b2782a882c69f46ae2a4
Above is your user manual download link. service manual below.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/ariston/Laundry/AWD12.pdf
Posted on Aug 09, 2010
    Brigadier General:
  • 3,513 Answers
Hi
The problem most likely is something stuck in the water port of the drain pump. The pump is located in the front right bottom of the machine and accessible by removing the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, and then disconnect the power connection from the pump. Disconnect the drain lines after removing as much water possible from the drum as the water will come out of these lines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump.
Check the bellow links for your query...
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Thecycledoesntadvance
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 07, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
Washer is full of water but will not spin
if your washer has old dial selector ,does it continues and finishes "cycle" without spining or does the selector stops moving also you could have a bad timer ,newer ones will have some sort of electronic module
Feb 23, 2012 | Kenmore Washing Machines
Cycle switch keeps tripping
Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Washer full of clothes and water and stopped- how to reset?
According to my experince let the machine stop and complete shut power and try after 10 minutes
Oct 03, 2009 | Maytag PAV2300 Top Load Washer
Dial keeps clicking around wont select a cycle, it was stopped mid cycle by accident then we tried to start at a new cycle ,since then the dial is costantly going around and the machine is full of water.
the washer is trying to reset its self. pull the washer out put the waste pipe to floor level to empty the water <not no your floor > plumb it back in then turn it on and it will sort its self out
Jun 21, 2009 | Washing Machines
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
76 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
