Question about GE Microwave Ovens
I have a GE microwave model jvm1430wd002. Lights and exhaust fan work but when you try to heat something it trips the breaker. I have tried several differant circuits and it does the same. One time the entire unit stopped working so I changed the 20 amp fuse and the lights and fan work fine but still no cooking.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
SOURCE: Model #JES2251SJ02 trips immediately 20
I called Public Service and they suggested either a dedicated line or upping tha amps of that c-breaker. I need to call an electrician to help me decide which is best for my house.
Posted on Aug 21, 2008
  • 211 Answers
SOURCE: microwave / Frigidare PLMV
What size breaker is protecting the circuit? Per the National Electrical Code, a microwave and a washing machine should each have their own dedicated circuit (and own breaker) rated at 20 amps. Also, if the breaker is old and has tripped many times due to continuous overloading, it may be weakened and could be tripping at a lower amperage than what it is rated. I would try the following:
1. If possible, test the microwave on another circuit and see if it trips that breaker. If possible, use a 20 amp circuit for the test.
2. If you're comfortable with working in an electrical panel safely, place a clamp on ammeter on the hot wire of the affected circuit in the panel and see how much current is being drawn when the microwave is on.
3. If you would rather stay out of the panel, get an inline ammeter/watt meter and plug the microwave into this. If the rating of the microwave is less than 15 amps (1800 watts), you may be able to use a device called a kill-a-watt at a local hardware store. This will show how much power is actually being used by a given appliance.
Posted on May 28, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Posted on Jul 07, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE jvm187osf02 microwave loses power
It may be a blown fuse or the thermal cutout (T.C.O.) or thermostat on the magnetron or on top of the oven cavity.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 20, 2009
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
When the microwave is turn on it trips the circuit breaker. The light and exhaust fan work but if you try use the microwave oven it trips the breaker. What is my problem. Thanks Mark
The magnetron is probably defective "heats food" and there are two other parts that work with the magnetron, the high voltage diode and capacitor which can be issues. The cost to repair will approach the price of a new microwave oven.
Jan 31, 2011 | Microwave Ovens
Microwave won't heat up after something caught fire.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
May 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Exploding microwave sounds - No Lights, No Fan, but Heats Okay
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 07, 2008 | Microwave Ovens
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Dec 13, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
