Question about HP PHOTOSMART PLUS B209A All-In-One Printer
How can I duplex print? I'm using Mac OS-X 10.6.4. Here's what I tried: I opened a pdf file with Preview, then selected File - Print... and chose Layout, and the Two-Sided option is off but greyed out so I can't change it.
  • 82 Answers
SOURCE: hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Posted on Nov 16, 2007
pagebor
  • 2785 Answers
SOURCE: HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Posted on Apr 28, 2008
SOURCE: Will not print Photoshop file
Have you check to see if this is a postscript driver you are using?
Posted on Oct 31, 2008
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 220 Answers
SOURCE: Greyed out duplex option Samsung CLP-310
does the printer have a duplex option,if yes should be able to print,check driver.if no,option does not allow you.
Posted on Jul 15, 2009
Sometimes I can't print with a pdf file on a
As I see that you are able to print some PDF file please try this one first.
Open a PDF that does not print>File>Print>Advance>Select Print As Image>Click OK to close>Print
Here is a link that has multiple ways to troubleshoot your pdf printing problem if the above does not work.
http://kb2.adobe.com/cps/873/cpsid_87346.html
Jul 16, 2011 | HP DESKJET 9800D 30PPM A3+ PAR, USB...
I have a pc and a macbook pro. I can duplex print on the pc but cannot seem to duplex print on the mac using word 2011. How do you duplex print using a mac and printing with a Samsung CLP 510 EMAIL
To print duplex on a Mac:
1. After finishing your document, go to File >> Print. You will see something like the following:tcdb28.png
2. Make sure that Layout is selected: tcdb28_0.png 3. Under two-sided, make sure than Long-edged binding (or something similar) is turned on. tcdb28_1.png
This will allow you to print duplex (two sided) on the Mac.
Feb 09, 2011 | Samsung CLP-510 Laser Printer
I transferred a PDF file from the Reader library on my MAC to the device but am only able to see about 18 of 484 pages. I checked the files on my MAC and in the Reader while attached to the MAC and I can...
I am not an expert on PDF's and I also have no experience with Apple OS, but I use a Sony PRS-600 and I thought of something that may possibly help you.
There could be some formatting commands or conditions contained within your PDF file that conflict with the Sony software and prevent portions of the file from being accessed. I suggest you try to reformat the file to see if you can get a "clean" version of the file. To do this you will have open the document and select "Print", however this is done on the MAC. This will send the opened file to a virtual printer and format it into a PDF file, hopefully creating a fresh copy that will be readable on the Sony.
In order for to you to be able to "print" PDF files you will need to install a suitable print driver.. I assume there are print drivers for the MAC, just as there are for the PC. Check the following website for more information on PDF printing on MAC's.
http://en.kioskea.net/faq/454-pdf-for-mac-os
There are numerous other websites dedicate to the download of freeware that can help you set this up.
For example -
http://download.cnet.com/Convert-to-PDF/3000-2084_4-10914935.html?tag=mncol;7
Having enabled your computer to print PDF's, open the PDF file in question on your MAC. Make sure, as mentioned in your message that all pages are accessible, then select the print command and re-print the file to PDF again. Transferring the file to the Sony device will then confirm if this approach is successful. This is not a proven solution but worth trying nonetheless. Good luck.
Jan 09, 2011 | Sony Reader Touch PRS-600
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Cannot compress a PDF
I assume you have tried the "reduce filesize" command. Try opening the file in Preview and print it - in the print dialog box select the pdf button, type a name and print. You get a file in the location you selected. This can reduce the size considerably.
Jun 26, 2009 | Adobe Acrobat 7.0 Professional for Mac
My printer won't print pdf files
SOLUTION: Either upgrade to Acrobat version 5 or higher, or use Preview as instructed below:
  1. Save the PDF file to the Desktop.
  2. Highlight the file and press Apple + i .
  3. Click Open with: and select Preview (default).
  4. Select File, Print .
Jun 16, 2009 | HP PSC 1350v All-In-One InkJet Printer
Phaser 8500 color printing issue - pdf file
Try setting up PDF direct printing..
> Support & Drivers > Phaser 8500/8550 Support > Search Results Solution: Perform PDF Direct Printing From Microsoft Windows 2000 / XP / Server 2003 OS and Apple Macintosh OS X (10.x) bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif PDF direct printing can be used to send a PDF file to the printer without having to open and view the file on a computer.
NOTE: PDF Direct Printing may not be successful if the printer does not contain a hard drive.
Depending on the OS being used, click on one of the following links:
Macintosh OS X
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
Feb 29, 2008 | Xerox Phaser 8500/DN Printer
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
502 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
