Question about RIM BlackBerry Pearl 8100
My palm is new, just got it why should i have to pay for help? After charging for 3 hours, I started the set up, during that process it shut down and will not power up.
  • RIM Master
  • 13,433 Answers
  • Ekse Apr 27, 2008
    link broken try again
    here
Samsung galaxys 2 drain battery fast
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
Dec 12, 2013 | Samsung Galaxy Tab 2 7.0
GPS keeps freezing, then shuts off, then restarts again, and it goes through the same process over and over again
I had a similar problem with my Garmin Nuvi 255. What I found was I needed to downloaded Garmin Webupdater from their website (not sure of the url) and download the new GPS software to my computer and then into my GPS ( in that order, they insist).
Make sure beforehand that you have charged your GPS at least 3-5 hours so that it has enough power to stay on during the entire process otherwise it could be rendered inoperable from the download.
May 12, 2010 | Tomtom ONE GPS Receiver
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Palm TX won't power up without charger
Replace the Battery. This has either a faulty Or Discharging Battery.
Even brand new items can have a faulty battery, or charging system
i,d suggest returning for replacement or refund, if it,s new/warranted.
Mike @ compurepair.
Jun 11, 2009 | Palm TX Handheld
My palm centro started going dead with a low battery signal literally overnight. I replaced the battery with a new one, and it still won't stay charged longer than 6 hours. Also the phone is now running...
I've had a Centro for 3 months and its such a let-down. Not only does the other caller find that my voice comes and goes randomly during calls but, like you, the battery started playing-up.
You'll find that a hard reset will bring the battery life back up. Hard reset clears EVERYTHING, so backup. To hard reset, remove and replace the battery while holding down the red, drop-call button until you are prompted to hard reset.
You'll find the battery life is bertter again, at least for a couple weeks...
May 15, 2009 | Palm Treo 500 Centro
Battery does not charge.
hi dear
try this
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
oke
or just try to use
http://mytreo.net/archives/2005/09/charge-your-treo-650-spare-battery-with-seidios-innocharger.html
oke
cropp
Mar 26, 2008 | Palm Treo 650 Handheld
Won't shut down
There are a couple of things you can try.
1- Poke the hole in the back where it says reset.
This will in essence reboot your Palm.
2- Make sure the Auto-Off after: is set to 2 minutes by going into the Preferences, Power section.
3- If your Palm is not holding charge, connect the Palm to charge it. Turn the Palm on and make sure the battery at the top has a lightning bolt going through it. This will let you know it is charging. Then, push the reset hole in the back to reset the Palm. This should reset the charging mechanism in the Palm and allow your battery to hold power.
If the Palm does not hold power after step 3, you may need to see about getting it serviced.
Jan 04, 2008 | Palm Tungsten E2 Handheld
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
