Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Food is not frozen in my freezer and i see water dripping i donot know why
  • 39 Answers
Can you hear the compressor (motor) in the rear of unit running ? Your freezer is thawing out for some reason and i would need to know if there is a digital temp.reading or is it a dile that regulates the temp.
Posted on Aug 07, 2010
Will 3.74cu.ft. freezer hold 95lb of food?
Hi Trish:
1 cubic foot of water weighs 62.4 pounds so if you had 3.74 cubic feet of water (not frozen) it would weigh just over 233 pounds.
Most of the frozen veggies you put in a freezer have air space and the specific gravity (weight per cubic foot) is quite a bit less than water. Meats are closer to the same weight per cubic foot as water, but you still have air spaces between the packages.
I'd guess that you could get 95 lbs of food in it but you would have to pack it very carefully.
May 18, 2015 | Freezers
The hose that allows water to flow into the ice cube tray is frozen. is this keeping my water from flowing out of the door
You'll need to get a blow dryer and then thaw it out so it can flow again. Move your frozen foods into the fridge while you do this. Let me know what happens. I might have another few ideas. Raz
Apr 14, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Evaporator coil in freezer red hot and water dripping on it.
This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
May 02, 2009 | Kenmore Freezers
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Apr 07, 2009 | Amana Freezers
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Freezer water line frozen
Sounds like your defrost sensor is not working the sensor should return the fan running and cooling after it senses 50 degrees in the condensor housing unplug the sensor and check if it shows a closed circuit. First unplug the freezer for your safety
Let us know what you find.
Sep 30, 2007 | Beverage-Air Freezer K Series Reach in...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
131 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
