Question about Dryers
It only runs when I hold in the start button - Dryers
    Sergeant:
  • 216 Answers
This is likely cause from the start run switch. When the dryer start button is pushed (push button is a monetary contact) it sends a current to the start run switch on the motor, the motor starts turning and the switch recieves a signal to stay running. If you remove the inspection door on the rear of the dryer and look at the electric motor you will see a little switch with the wiring harness attached to it. This switch is the likely culprit. You can easily replace this switch by first disconnecting the power, then remove the inspection door or back cover. Then remove the mounting screws. Using a piece of paper draw a diagram of the switch and wire position alone with there color so that you can easily replace the switch. Install the new switch, replace the wires and you good to go.
Some times in really rare cases it could be the electric motor, Because the motor has to be turning at a predetermined speed to trigger the switch, if the motor is not turn fast enough due to worn bearing or faulty armature this too could be the issue. Whoever I would suggest replacing the centrifugal start / run switch.
Posted on Aug 07, 2010
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
