Question about Car Audio & Video
Which color wire is the antenna wire that goes to the amp for a panasonic cq-rx420w
  • 239 Answers
Blue/white
thumbs up pls
Posted on Aug 12, 2010
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
CANT FIND MY MANUAL! DONT KNOW W/C WIRE TO POWER UP MY AMP? TRYING TO HOOK UP AN AMP IN MY CAR
Blue/White Stripe = External amplifier control power lead
Blue = Antenna control lead
Red = ACC power lead +12 Volts
Yellow = Battery lead Constant +12 Volts
Black = Ground lead
Here is the manual for the Panasonic CQ-C1300U CD Player.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 27, 2010 | Panasonic CQ-C1300U CD Player
Bought brand new car audio head unit CQ-RX420W. 2 questions if anyone can help please. 1. The aerial wont retract when a non radio source is selected. 2. There's no orange wire in the loom for dimming the...
The antenna generally will not retract until the power is turned off at the deck or if you turn the key off (which turns the deck off).Your deck may have a selectable dimmer function in the settings menu you should be able to set it to automatic and it will handle the dimming on its own then.
Jan 30, 2010 | Panasonic Car Audio & Video
Bought brand new car audio head unit CQ-RX420W, but no installation instructions. Blue and brown wires, not sure which is for aerial and what the other is for. Can you help?
what you have there is a good panasonic head unit. the solid blue wire is going to be used for an automatic antenna.
Yellow- Constant Power (keeps memory for your clock and presets)
Red-Switched Power (turns your radio on when you turn the key)
Black-Ground
White- Left Front speaker (+)
White w/ black stripe - Left front speaker (-)
Gray - right front speaker (+)
Gray w/ black stripe - Right front speaker (-)
Green- Left Rear Speaker (+)
Green w/ Black stripe Left Rear speaker (-)
Purple - right rear speaker (+)
Purple w/ black stripe - right rear speaker (-)
Blue with white stripe - power out, (commonly used for the amplifier turn on wire, or antenna wire.
you may have orange wires in your harness,
or brown ones. these you dont really need
the orange wires are for your dash board dimming lights
and the brown one is for Tele, Muting.
what kind of car do you have, i can give you the wire harness colors
Dec 30, 2009 | Car Audio & Video
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
Installation
the blue and white wire is for the powered antenna, or signal remote wire for amp is also ran off that wire. as far as internal ant. cap you would have to check with panasonic about the add-on from factory though it does not. you should have a powered antenna or antenna in the windshield on the vehicle unless someone has changed the windshield for the cheaper model or removed the external antenna. which in that case you will need to add an antenna, can be bought at local electronics store or stereo shop. hope this help solves problem let me know if you have any more questions.
Mar 04, 2009 | Panasonic CQ-C3303U CD Player
CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Dec 31, 2008 | Panasonic CQ-RDP162
Wire identification
I dont have schematic but I know that the lt. green goes to emergency brake switch, I have the blu wire hooked up to my amp remote, orange may be for dimmer when headlights are turned on, blu w/wht. stripe I'm not possitive but I think its for an electric antenna, my cq-vd6503u does not have a pink wire.
Oct 20, 2008 | Panasonic CQ-VD6503U Car DVD Player
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
