Question about Samsung BN59-00599A Remote Control
How do i program it to my samsung tv code: LN32B360C5D
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Samsung LN32B360C5D Repair
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Check the voltage that comes to the back-light inverter board; from the main power board. The absence of this voltage too can be the cause.
Oct 15, 2014 | Samsung Ln32b360c5d
Parts samsung ln32b360c5d
Contact the authorized service center for Samsung.
Jun 24, 2013 | Televison & Video
I have a Samsung 360 series 3. LN32B360C5D model. purchased Dec 2009. will not turn on. no light or sound. tried everything and will not work
Attempting to do service opening the back cover is not advisable, since there are hazardous voltages present even when the power cord is not plugged in. It is better to refer it to a qualified service technician.
Aug 16, 2012 | Samsung LN32B360 32 in. LCD HDTV
S/N AZA43CRSA16199J MODEL LN32B360C5D BUY IN 2009 POWER GET OFF SCREEN GET BLACK NO SOUND
Thanks for stopping by.
Typically, for the symptoms you have described - the power supply board likely has failed capacitor(s). If you were to remove the back of the set - you'd probably notice the power capacitors leaking or bulging.
For your Samsung LN32B360C5D CLICK HERE to see your board/replacement.
The big yellow capacitor in the middle is the likely culprit.
While you have it open - check the fuse near the power plug as well.
This is not something that will correct with a reset or button press - it will require repair.
If you have it to a repair shop - expect a $75 component repair charge. If the board cannot be repaired - the board itself is $89-$135 plus 1 hour shop labor to replace.
Thanks!!
Sep 18, 2011 | Samsung LN32B360 32 in. LCD HDTV
Where can I get a free user Manual for Samsung LN32B360C5D
From Samsung's official site would be the best source:
Go to http://www.samsung.com/us/support/downloads/LN32B360C5D and click on the PDF icon next to the User Manual
Aug 25, 2011 | Televison & Video
I just upgraded my LN32B360C5D firmware to 1016.1,
If you weren't having problems, you shouldn't have updated. Samsung on their site says DO NOT UPDATE if you are not having problems... don't fix what isn't broken, now live with your mistake.
Dec 26, 2009 | Samsung LN32B360 32 in. LCD HDTV
Samsung BN59-00599A Remote Control Logo
170 people viewed this question
Jerry Greenberg
Jerry Greenberg
