Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Fill with water, stop then no agitation. Please help
Everything was going well, this morning fill the washing machine with water then, nothing!!!  Would like to fix myself, but don't have a clue.
  • Anonymous Apr 27, 2008
    drained unit now what
  • ANICEGUYNDAD Apr 28, 2008
    My whirlpool top load ultimate care plus washer won't agitate or spin. It does make a buzzing/clicking sound from the back. It does drain though. The center agitator won't budge or spin and seems stuck. HELP Please!!
It just buzzes and clicks
Posted on Apr 28, 2008
    Genius:
  • 1,028 Answers
Ck left hinge screws lid switch is under left rear and is tough to acess if switch seems suspect 2 screws in rear of console are removed and console rolled back to acess switch also ckd wires to motor have seem problem with poor contact in motor connector
Posted on Apr 27, 2008
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
    Not filling with water. everything else works. it will agitate without the water in the tub. it thinks there is water in it
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    heatman101
    Aug 30, 2010 | Maytag Dependable Care LAT9706
    Washer is getting stuck at rinse cycle-
    sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
    May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Washing machine fills, but will not agitate, drain or spin
    Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
    Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Will fill and drain, not agitate or spin though
    I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
    Jan 22, 2009 | Roper Washing Machines
    Ge top loader washer agitator does not work
    To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
    Nov 27, 2008 | Kenmore 22422 Top Load Washer
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    47 people viewed this question
    Dan Webster
    Dan Webster
    Richard Roth
    Richard Roth
    Mike Cairns
    Mike Cairns
