Question about GPS
Top third of the screen is a mirror of the bottom third and is a different color (red). Garmin GPS Map 176C
  • geoffgow Aug 07, 2010
    This is not a touch screen model. I have already tried a system reset that did prompt me about losing all my data. It did not help the problem. Perhaps there is another kind of reset I could try? The one I followed involved holding down menu and the quit key while powering on.
    Please take a look at the following link:https://forums.garmin.com/showthread.php... There are others with exactly the same fault. I would post here on the Garmin forum but I can't get an account to activate and it's the weekend with no support at Garmin until Monday. I wonder - with this not being an isolated problem - if there may indeed be a fix for it ??? Thanks
  • 787 Answers
That is clearly a mainboard problem. You need to have it replaced.
Posted on Aug 07, 2010
  • 472 Answers
Your GPS device has gone faulty. Resetting is just a lucky fix. It is a hardware issue and the problem is that Garmin no longer support Garmin GPS Map 176C so its time to buy a new GPS device.
Good Luck!
    Yeah - that sure might be the case. Please take a look at the following link: https://forums.garmin.com/showthread.php...
    Genius:
  • 1,478 Answers
I suggest you reset your GPS, to reset it, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, your GPS will perform better.
Take care.
    Thank you. This is not a touch screen model. I have already tried a system reset that did prompt me about losing all my data. It did not help the problem. Perhaps there is another kind of reset I could try? The one I followed involved holding down menu and the quit key while powering on.
    Thanks
Gps nuvi it alays say no match found
Every Garmin Nuvi has a map info screen. check to make sure your Garmin has maps
usually that screen is
Tools;
Settings;
map;
mapinfo (at the bottom)
or
Settings;
Map and Vehicle;
My Maps;
If it is greyed out or a blank screen then your garmin is missing its maps. otherwise, make sure the maps are checked and make sure you are searching in the right area. by default the Garmin will search within 50 miles of you.
Aug 03, 2014 | Garmin nuvi GPS
Garmin nuvi 1100 gps. Screen says no map data. Is there a default setting?
The map may have become unselected.
Press TOOLS, the spanner symbol on the page that shows WHERE TO and VIEW MAP
Press SETTINGS or LOCALE on some models
Press MAPS and then at the bottom of the screen press MAP INFO
Your map name should be displayed. THere should be a tick beside it. If there's no tick press the map name and it will tick. The map is now selected and should work ok.
Feb 27, 2011 | Garmin GPS
How can I change my Garmin Nuvi from germany to australia
go to Tools.... Settings..... Map..... on bottom of screen press Map Info.... put a check mark in the map you would like to use.....only one map at a time so if your in Germany place check in Australia when you enter
Nov 10, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi lost all themaps.
Check to make sure your map is selected first..
Go to Tools.... Settings...Map.... on this screen on the bottom press Map Info
now make sure that City Navigator North American NT is checked
Nov 07, 2010 | Garmin nuvi 205W GPS Receiver
The GPSmap 176c does not turn on. I have put in new batteries and cleaned the metal parts of the battery receptors
Do you use rechargeable batteries? The 176C seems to be extremely picky about the voltage. I had the same problem. Afer changing to non-rechargeable batteries, everything works fine again. Not great for the environment, but for my bearings.
Jul 12, 2009 | Garmin GPSMAP 176C GPS Receiver
Will not power on
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Apr 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Garmin 350 won't navigate
Click on Settings
Click on Map
Click on Map Info tab at bottom
Make sure the map info is checked, if it isn't you won't get any POI.
Mar 03, 2008 | Garmin nuvi 350 GPS Receiver
My 176c is not responding
get the download (updater from garmin website , download it then hook up 176c to computer and run file .if it doesnt go thru hit power and try again if you get the screen under a good light so you can see it will say downloading when this is done your screen will be back to normal .I dont remember if the unit is on when it beeps or off .try both ways if it doesnt work replace batteries as even though your not seeing the screen the unit is still on like i said ; fresh batts and try it and if it doesnt work hold down power key for a second or two and try again. good luck PS garmin doesnt know this i figured it out myself ...bob
Feb 24, 2008 | Garmin GPSMAP 176C GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
