Question about Garden
Have a john deere lx 75 rider. Don't see any fire at the spark plug. Any ideas for a simple fix?
  • Dave Aug 14, 2010
    no simple fix other then try new sparkplug...if still no spark probably needs new coil assy
  • 246 Answers
SOURCE: manual John Deere lawnmower
Hello lcurfman:
>>You can obtain Technical Information (operator's manuals, parts catalogs & service / technical manuals);
Call 1-800-522-7448
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 41 Answers
SOURCE: looking for a manual for a John Deere RX 75
go to the John Deere web site and search for your model number. They have publications there online and some that you can buy.
Posted on Jul 15, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
RX 75 It won't start.....
change the spark plug. i have had 3 rx 75 that after i changed the spark plug they ran fine.
May 14, 2016 | John Deere Garden
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
Oil leak on John Deere LX 277
wash the engine area down and run it while watching for the leak
Aug 13, 2012 | Garden
75 John Deere 2030 gas tractor will not start. Changed plug wires, plugs, drained tank, new gas, new battery, new coil, new wires, getting spark turns over but does not fire.
first thing is to test and see if it is firing,if so clean out the carberater.
make shure all moving parts are clean inside and out,flotebowl,neddle valves,and jets should be
free of gunk and allow good flow of gas.
Jun 25, 2011 | Garden
John deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
May 02, 2010 | Garden
John deere lx 178 1 cylinder firing
pull plug if its wet you have a firing problem if not the you have a fuel problem! been my expierence use only jd parts on that bad boy! little more $ save you several little head aches!
May 26, 2009 | Garden
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
