Question about Kohler Acorn Lift-Knob Flush Actuator Toilet Handles
I am looking for the part to replace our kohler Acorm lift knob flush toilet handle that has broke,
  • 70 Answers
Ferguson supply house
Posted on Oct 27, 2010
Kohler 3810 toilet wom't flush
Check and see if the handle or the chain inside the tank is broken. If it is, find out the make and model and get replacement. There are many different types of handles out there. Some universal handles won't work, so bring the handle with you when you buy a new one..
Mar 24, 2017 | Kohler Plumbing
When I flush the toilet the handle stays down and therefore the toilet runs on. How can I fix it?
If you lift the lid you should see where the handle goes through the porcelin. You can remove the handle by unscrewing the nut inside the tank. Try cleaning the inside of the nut as sometimes water deposits collect in this area and cause binding on the handle shaft. After you clean it up you can apply a very small amount of petrolium jelly to the handle shaft when you reinstall it, this should prevent the problem from happening again.
Jun 09, 2011 | Kohler Toilet - One Piece with Ingenium...
When I try to flush the toilet, the handle barely moves and when I look inside to see what the problem is, the silver arm moves only slightly and it does not lift the black cylinder.
You just need to adjust the chain attached to the silver part. Just unhook it and go up maybe 3 links on the chain. This will help it lift up higher when you go to flush it.
Apr 10, 2011 | Kohler Cimarron Comfort Height elongated...
I have the Kohler toilet with the top actuator, it flushes fine but won't stop running. If I lift the tank top I'm making the toilet flush again. Can this be fixed or do i have to replace the whole system?
(Problem 1) if you can see the water running in the bowl it's a good chance that the flappers warn. you'll have to look at the angle where the light hits the water. The water will be rippling where the top of the water meets the inside of the bowl edge.
For more info on how a toilet works = http://www.aplumbers.com/residential/toilet
solution 1
1. tank the tank lid off.
2. flush, the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2 it could be the water levels to high.
(solution 2)
1. tank tank lid off.
2. if the waters flowing over the long tube in the center and down then the water level is too high 3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing. 4. adjust water level . 5. lift the flapper to allow a little water out til fill valve kicks on then release handle til valve stops . 6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 14, 2010 | Kohler Acorn Lift-Knob Flush Actuator...
I have a new Kohler toilet. Sometimes after flushing the handle stays down and the closet does not refill because the flapper is in the up position. I thought it was an air pressure problem because when...
is there a chance you have an air pocket in the flapper itself... try replacing flapper with a solid black rubber one.... they have more weight to them maybe the lever on the out side of the tank is getting caught up on the bottom of the lid
Oct 07, 2010 | Kohler Home
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Acorn Lift-Knob Flush Actuator Toilet Handles Logo
166 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
