Nero 8 im using nero 8 and was t old this would be the best software to use for transfering my films to disc . ive followed the steps and it encodes the film then tells me its burning it to disc, this process takes about 1hour 50mins or so , it then tells me that project was sucessful! Great yes? no! when i remove the disc and then try to play it back its always empty! ive been trying this for 2 weeks now could you advise me as to why this is happening please and or advise me if there is an additional software i should add to nero 8 to rectify this problem regard Lisa
    President:
  • 1,257 Answers
There might be a lense problem in your cd dvd writer,if you are burning dvds check whether it is combo or dvd writer, because combo drive only reads dvd but not burning...
or attach your writer to any other system to know whether there is a problem with your writer or with your burning software.
if it runs ok with other system ,means there is a problem with your burning software i.e nero 8...
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Posted on Apr 30, 2008
I have a 97 Chevy blazer with push button 4 wheel drive and it don't shift In to 4 low or 4 hi and the light should flash for 30 second then go back to 2 hi if it can't shift but when you push the button...
How about to the switch , is there battery power ? Fuse #15 FWD 10amp. I/P fuse panel . BCM - body control module light's the switch indicators 2hi, 4hi,4low . Check fuse #6 10amp I/P fuse panel .
DTC 002
The transfer case encoder motor is an assembly which houses four separate channels. These channels are used to indicate to the transfer case shift control module the present gear position of the transfer case or if the transfer case is in transition between gears. The encoder motor assembly consists of an electronically conductive inner ground ring in contact with a three legged wiper arm. Each leg's length is such that it makes contact with the conductive regions of the four channels. When any leg of the wiper arm is making contact with the conductive area of any channel, the encoder provides a path to ground to the inner ground ring.
During electronic shifting, the transfer case shift control module monitors the transfer case encoder circuit for the proper operating sequence. If at any time during a shift, the encoder changes from one position to any position other than the next possible position, an error counter in the transfer case shift control module increments by four. After the counter reaches 32, the transfer case shift control module set a DTC 2, a permanent "encoder fault," and reverts to a 2HI to 4LO or a 4LO to 2HI shift pattern only. To guard against a transient, random encoder fault due to vibration, dirt, electrical noise, etc., the fault counter reduces by one each time the transfer case shift control module detects a valid encoder value. The encoder must intermittently fail 25 percent of the time for the transfer case shift control module to consider it faulty and store DTC 2.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step measures the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
This step tests the suspect circuit(s) for an open, short to power, or short to ground.
This step tests the encoder signal ground circuit for an open or high resistance.
DTC 2 -- Encoder Fault Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Important: Check the transfer case shift control module for DTCs. The transfer case shift control module is not a class 2 device. DTCs are displayed on the transfer case shift control switch. Use the following four steps to obtain DTCs.
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes.
Did you perform the Diagnostic System Check - Transfer Case?
YES - Go to Step 2
NO - Go to Diagnostic System Check
Disconnect the connector at the encoder motor.
Measure the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
Does the voltage measure near the specified value?
4.8-5.1 V
YES - Go to Step 4
NO --Go to Step 3
Test the suspect circuit for an open, short to power, or short to ground. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 8
NO - Go to Step 7
Turn the ignition switch OFF.
Test the encoder signal ground circuit for an open or high resistance. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
YES - Go to Step 8
NO - Go to Step 5
5
With a DMM at the transfer case module connector probe the encoder sign ground pin and ensure a good ground path through the module.
Did the DMM indicate a good ground path?
YES - Go to Step 6
NO - Go to Step 7
6
Replace the transfer case encoder motor. Refer to Motor/Encoder Replacement .
YES - Did you complete the replacement?
NO - Go to Step 8
7
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
NO - Go to Step 8
8
Clear all DTCs from memory. Refer to Diagnostic Trouble Code (DTC) Clearing .
Operate the vehicle while pressing each of the buttons on the transfer case shift control switch.
Does the DTC reset?
YES - Go to Step 2
NO - System OK
Aug 29, 2017 | 1997 Chevrolet Blazer
How do I copy the mini disc onto a dvd disc, is there a converter program I need to download so that I can then burn several mini discs onto a 2 hour dvd?
Hi, You can convert mini disc ( 8 cm diameter ) to a standard DVD disc via your PC. Please follow this steps : 1. Install your canon software/driver in PC 2. Install DVD creator in PC ( common software is use Nero scout) 3. Download your mini disc data to PC 4. Enhanced your data with Nero 5. Burn your data to standard DVD
Make sure you have DVD RW hardware in your PC.
Dec 04, 2010 | Canon DC210 DVD Camcorder
I cant use labelflash
Hello muneef_almul
If your optical drive support labelflash. Only you need is labelflash burning software like Nero 8 or Nero 9 and LabelFlash compatible CD/DVD media/disc.
You can use Nero Cover Designer to design you label and burn it on your media.
Try this step by step guide provided by Nero http://www.nero.com/enu/support-nero9-labelflash.html#tab3
LabelFlash media/discs you can buy from any Computer shop or Supermarket. You can find some from online shops for example http://www.google.com/products?q=%22labelflash%22+media&hl=en&aq=f
I hope this will answer your questions.
Dec 19, 2009 | Computers & Internet
How do i fix my nero 8 seria number which has expired
1.Install nero using the serial below: -
7K22-OO1B-11OS-E1SS-S9M4-B4X3-7E11
2.Now go to start, all programs, nero 8, toolkit then control centre.
3.Will see list of nero apps installed. At bottom uncheck (check for updates)
4.Left hand side click the KEY icon.
5.Enter following serials:-
-Blu-ray/HD DVD Video Plug-in:- EC06-206A-99K5-2527-940M-3227-K7XK
-mp3PRO Plug-in:- 9C00-E0A2-98K1-294K-06XC-MX2C-X988
-Lame MP3 Encoder:- 4C04-5032-9953-2A16-09E3-KC8M-5C80
-LLS Plugin:- EC05-E087-9964-2703-05E2-88XA-51EE
-HDDVD_TEST:- 5C0X-205M-99M1-2435-2118-K246-1576
-NERO_TEST:- 4C0E-4009-9863-2X6M-1939-12A1-99A0
-BD_TEST:- 5C0M-6027-1869-2C4K-4001-81E0-K6CA
6.delete "NeroPatentActivation" in C:\Program Files\Common Files\Nero\Shared\NL3.
Or block internet access via firewall.
7.you are done
8.dont forget to reply to my topic
Aug 01, 2009 | Ahead Software 8 Ultra Windows
Nero express 6 not working
my nero says encoder has expired but dosn't say how to get it
Aug 24, 2008 | Ahead Software Nero 6.0 (60045) for PC
Pioneer bus cable wiring
You asked for it...
..it's a little complicated.
The pioneer IP bus uses a 2 wire differential signal for communication.
An equal level on both lines is a logical low while a high is encoded as a voltage difference of some 100mV.
I think a CANbus tranceiver should work here.
The data transfer is initiated by either the cd changer or the radio.The initiator generates a high pulse ( ca. 170us ) and a following low pulse ( ca 20us ).
Then the data transfer starts, a 1 is encoded as a high-low sequence with a duration of ap. 20us for both levels and a 0 consists of a 33us high and a 7us low pulse.
The data is now transfered in bytes with MSB first, the 8th bit is an odd parity bit.At the end of the 3rd and all following Bytes there is an additional bit inserted after the parity where the receiver acknowledges the transfer.
This is done by holding the data lines in a high state after the initiator sets them low.If this ack is missing the transfer is stopped.
The timings may vary because the real data is encoded in the pulse to space length relation.
The first 3Bytes seem to be some kind of device address.The changer I used transfered a 0x88,0x68,0x00 here while the radio sended 0x88,0x08,0x06.
The next 4 bits were always high. After that a size byte and then size bytes were transfered. The last byte in the transfer is a checksum generated adding the values of all data beginning with the 4bit sequence ( = 0x0F ).
In the following part I only will write the raw data excluding size and cheksum field.
Each command transfered was first answered by some acknowledge packet consisting of a single 0xA1.
(which looks like: 0x88 0x08 0x06 0xF 0x02 0xA1 0xB2 -> 0xB0 is the checksum ).
For now I just figured out some very basic things like the fields where time, track and disc number are encoded and also some
key codes the radio sends. There are many more fields in the packets where i still don't know the meaning of.
(I just got the radio from a friend for some days and so I couldn't do so much more on it ... however .. if somebody is intrested in some
more information and is wiling giving me a radio and a changer for some weeks I'll try to do some more .... )
I have also designed a small circuit using a AT90S2313 controller which can be used for logging the transfer through the pc serial port and also
to send commands.
The following packet sended by the changer contained the time disc and track information.
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Info command modus mcd disc min sec track cdt Data 0x61 0x10 0x06 0x01 0x20 0x04 0x16 0x01 0x06 0x01 0x00 0x00 0x01 0x00 0x3F 0x00 0x00 0x00 0xC0 0x48 modus:
Value 0x02 0x07 0x08 0x10 0x11 0x13 0x14 0x15 0x16 Info ready track blink pause ready and disc blink disc blink load and disc blink eject and disc blink load eject cdt: bit0: (1:cdtext),(0:normal)
The text information was encoded within this packet
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13-22 Info command modus disc track text seqence number text Data 0x61 0x10 0x06 0x01 0x20 0x04 0x38 0x09 0x00 0x06 0x00 0x00 0x00 0x00
Recommend link: Vitaliy's Page @ http://www.vitat.spb.ru/ with IP bus interface on AVR basis and more IP bus informations
Some transfer log files are available.
Jul 20, 2008 | Car Audio & Video
Nero 8 what am i doing wrong
If it's a movie file like avi or any other, u don't need to encode it.
just add the files into burn category and burn.
thank you!!!
Apr 26, 2008 | Adobe Photoshop 7.0 for PC
Why doesnt nero 8 let me burn film to disc
There might be a problem with your dvd lense of your dvd burner,sometimes it happen when the burner software dont recognise cd or dvd..also i would like to suggest you to use original burner software for burning cd dvd's...sometimes it also happen that the burning software dont burn certain types of audio or video files.for eg nero 6 dont convert .vob files to convert.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Computers & Internet
Dvd
it all depends on wot u used to burn it, and wot type of dvd player u have, there r diff ways to get it to play, on a normal dvd player u will either need to encode the movie file into a vcd and put it on a cd or encode to dvd format and burn it onto a dvd using programs like nero or roxio
Jan 27, 2008 | Televison & Video
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
