SOURCE: remote starter disabled and key will not start truck
Interface kit went bad life time part goto dealer and have replace should take 20 min
There should be a Valet/emergency override switch, you must turn the key to the on position and switch the switch ... the LED should come on solid, try that, if no go .... Call the people who installed the system ... it is malfunctioning .... If you have RF key ... it may be being interfeared with buy the security override system that is required to remote start the car ...
SOURCE: Disable or disconnect the factory installed alarm
should be a fuse for it, just remove it......
SOURCE: I have an older clifford alarm arrow 3.
im puting a after market alarm on a dodge ram 09 how do u do door locks
SOURCE: I have a new prestige APS-57C remote starter
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
