Question about RTO Oar Sockets
Do you no flywheel torque settings for tohatsu 30hp single cylinder 2000 model its rebranded as 30 merc liteweight model
Tohatsu 30hp M30 outboard.
Sound like problem with ignition or fuel delivery system
Feb 22, 2018 | Boating
Husqvarna yth22v46 no start. Backfires
Most common issue with this engine is a broken flywheel key. The key is a small piece of metal used to locate the flywheel to the crank. if the flywheel nut is not to the right torque it can slip breaking the key and putting the ignition timing out. Your symptoms fit this.
This page shows single cylinder engine info, but it is relevant. I quick search on YouTube will show many videos on how to check and replace this key.
How to Inspect Flywheel Key for Replacement Briggs Stratton
Jan 22, 2018 | Cars & Trucks
Torque Settings For Mazda WL Turbo Engine
TORQUE SPECIFICATIONS all readings in ft. lbs.
This for 2000 model I do not know the yuear of your car.
Year Engine Displacement Liters Engine VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Intake Exhaust Spark Plugs Oil Pan Drain Plug 2000 2.5 C ? ? ? 103-133 54-64 3.0 U ? 60 26 107 54-64 4.0 X ? 66-77 19-24 ? 59
Apr 11, 2016 | Mazda Cars & Trucks
I have a 94 Hyundai Excel. I am replacing the clutch but can't find the torque settings anywhere.
clutch/flywheel torque settings - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...accent/146383-clutch-flywheel-torque-setti...
Aug 2, 2012 - 3 posts - ‎2 authors
Im after the torque setting for the clutch and fly wheel for a lc 2000 accent with the dohc 16v engine. cheers.Missing: .94
Torque value head bolts 1994 hyundai excel 1.5l - Fixya
www.fixya.com/cars/t12339610-torque_value_head_bolts_1994_hyundai
Apr 7, 2012 - SOURCE: torque settings for a hyundai accent 1500 1998. cylinder ...SOURCE: how d i change a clutch in a hyundai excel 1994. Hi first lift the ...
Flywheel & Pressure Plate Torque Specifications? - Hyundai ...
www.hyundaiaftermarket.org > ... > Engine, Intake, Exhaust
Dec 19, 2015 | Hyundai Cars & Trucks
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Toyota 2c. I need cylinder head and flywheel Torque settings
Toyota 2c ...
USE NEW BOLTS...
Torque sequence:
You're driving a diesel single cylinder head engine. Engine head torque has to be done in specific order and stages if not can warp head or break bolts. Suggest you get torque sequence and torque specs from your Toyota dealer, they can give you correct answer. Don't trust answers on here, if you choose wrong specs. could end up messing up head.
Flywheel - Use a Sealer on bolt, Manual Transmission 88nm/65 ft lb... Auto Transmission 74nm/55 ft lb
Aug 06, 2014 | Cars & Trucks
Cylinder head torque spec on yamaha 30HP
Bolt torque is based on 75% of the bolts strength so you can use a standard torque chart based on bolt size. There are many online charts to help, just google "torque specs for metric bolt sizes chart"
hope this helps you.
Dec 09, 2013 | Light Boating
Torque specs for cylinder head on a 200 ford focus with 2.0 ltr single overhead cam. and for connecting rod... Thank you much.
  1. CAUTION: Always install new cylinder head bolts. NOTE: Lubricate the cylinder head bolts with Super Premium 5W 30 SAE X0-5W 30-QSP or equivalent meeting Ford specification WSS-M2C153-G prior to installation. Install the cylinder head assembly and tighten the cylinder head bolts in the following sequence.
  1. Tighten all bolts in a single sequence to 50 Nm
  2. Back the bolts off 1/2 turn.
  3. Tighten the bolts in sequence shown to 50 Nm .
  4. Rotate all the bolts in a single sequence an additional 180 degrees in two steps of 90 degrees each.
9 3 1 5 7
8 6 2 4 10 sequence for head
Spec for rod 38Nm
May 07, 2010 | 2000 Ford Focus
RTO Oar Sockets Logo
82 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
