Question about Samsung LA40A450 40 in. LCD TV
Television will not turn on; it's plugged in, the red light is blinking, but it doesn't turn on! The TV was working fine earlier, I turned it off with the Charter cable switch, after I had paused a show on Tivo (?). I have unplugging everything, turning the TV on from the cable remote, the television remote, and the switch on the TV itself. Help!
    Champion:
  • 367 Answers
I would have to say that you have bad capacitor in the power supply.Have you taken the TV apart?If you can take it apart,and send some pictures of the board with the power cord going to it,I can tell you which capacitors if any are bad.They have a rounded top to them instead of being flat.Also,how many blinks does the power light blink?Usually it's a series of flashes,and then it repeats.I hope this helps.Thank You very much!
Tyler
Posted on Sep 23, 2010
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Samsung LA40A450 40 in. LCD TV Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
