Question about Kenmore 700 6972 Dryer
My kenmore dryer wont get hot... I got the proper voltage, what can it be?
  • 5,911 Answers
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If your ELECTRIC dryer is running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat.
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
NOTE: The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on Aug 07, 2010
3 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Posted on Jun 28, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Aug 11, 2009
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Jun 22, 2014 | Kenmore Dryers
My kenmore elite electric dryer wont get hot
The motor works on 120 volts the heater is what requires 240. I bet you have an electrical problem
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 12, 2012 | Kenmore 400 6942 Dryer
Our kenmore s70 dryer heats up but wont stay hot all lint is out,never a problem why wont it stay hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Kenmore 72822Gas Dryer
My old Kenmore dryer stopped sending hot air. How can I fix it.?
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 17, 2010 | Kenmore Dryers
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
I just bout a ge dryer and washer set. the top gets really hot and it wont dry the clothes.
Sounds like the thermostat was not set properly at the factory. Call GE's service number located in your owner's manual for service.
Dec 19, 2009 | Kenmore 73952 Gas Dryer
I have a Kenmore Elite HE3 dryer model # 110.8483220. It has no power. We tested the plug and it tests for 110V of power, and the wire connection at the top of the dryer (on the outside) has power. But...
Your dryer is electric. This means it needs 2 electrical phases (hot wires) and one neutral to wor. If you measure 110v across 2 phases - one of them is out.
Unplug the dryer. Find the double breaker for your dryer on the breaker panel.
Pull breaker to the off position hard (do not overdo it,as you can pull the breaker out), and then back to on position.
Check voltage between the two phases, it should read 220-240v. Check the voltage between each phase and the neutral (middle prong), should read 110-120v. If you don't get these readings - call electrician.
If you get the proper voltage, plug the dryer back in. If it does not work - Dryer needs repair. Likely a thermal fuse is blown or problem with power wiring inside.
Oct 13, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Will run but will not heat up
If the dryer runs, but does not heat, the first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If your problem is with the dryer heating circuits, the following link explains what to look for and how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. The number one cause of dryer heat related problems are caused by poorly installed, kinked, or clogged dryer ventilation. If you have any questions, please let me know. I hope you find this information helpful.
Jul 11, 2009 | Kenmore 75944 Gas Dryer
Kenmore 700 6972 Dryer Logo
246 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
