Question about IBM NetVista PC Desktop
How to repair missing wininet.dll? - IBM NetVista PC Desktop
    President:
  • 48 Answers
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Posted on Aug 07, 2010
My Optiplex GX270 is not booting up past Windows log on page, it has a pop up WININET.dll was not found. Re imstalling the application. may fix this problem. What if anything can I do to salvage this old...
It has a Windows file missing (and usually many others). The most common reason is hard disk failure. When Windows files just start to disappear, it is usually a sign that the drive is dying. It can also be caused by virus activity, but it is rare if you have a good antivirus package. It would pay to get the hard disk checked.
Jan 26, 2014 | Dell OptiPlex GX270 PC Desktop
I have an HP Mini 1000- when I start windows I get a message..."wininet.dll was not found. re-installing this application....." Since there is nothing I care about on the hard drive, I was...
simply insert a windows install disc into the laptop and restart it. you should get a prompt telling you an operating system disc has been detected, and how you wish to proceed. you can either attempt to fix with a the repair tool, or reinstall windows.
Mar 28, 2011 | HP Mini 1000 Netbook
RE-INSTALL WININET.DLL FOR ASUS EEE PC 900HD
reformat your notebook then look for a compatible OS.
May 02, 2010 | ASUS Eee PC 900HD Netbook
"unable to locate component" pop up
the wininet.dll file from microsoft.
this file is missing
http://attachments.techguy.org/attachments/111158d1184798685/wininet.zip
please get file from this site and put it in your system
copy to c:windowssystem32
let me know...datarecoveryfactory
Sep 06, 2009 | Microsoft Windows XP Home Edition
Missing wininet.dll no disk
probably u are trying to reinstall the same windows program that is damaged and is still in the cpu. find another windows disk and dowload this from "bios" (select the option "download from cd-rom") this will totally reset yr hard disk and all yr data and settings will be lost
Jan 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
My laptop was turned of during an recovery point[system restore]
Try doing a system restore from a previous retore point. However, you will not be able to recover any files that were saved after that point.
If all else fails, you may have to reinstall the OS. The "wininet.dll" file may be from some software you installed at a later point..
May 15, 2008 | Computers & Internet
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
IBM NetVista PC Desktop Logo
289 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
