Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
Just got a used Life Fitness 9100 treadmill. When I turn it on and press sstart the display says enter weight. Before I can enter my weight and press start it resets itself back to the enter weight screen. Does it need to be reset or something. I know it works, I used it 1 hr prior. Thanks
  • 79 Answers
This problem is due to a false in the terminals that connect with the microswitch, you must remove the screen and back-side only remove the screws and tighten the terminal could also apply contact cleaner
Posted on Sep 07, 2010
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
Mar 30, 2013 | Life Fitness 9100 Next Generation...
Life fitness 9500hr?it wont start and says ....see maintance on display?any ideas
just bought a amazing model after reding review on this site thanks amazon rock http://www.pianoforall-review.com/life-fitness-treadmill-reviews-does-it-works/
Dec 03, 2012 | Life Fitness 9100 Next Generation...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
    see this step and fix it. God bless you
    Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    Aug 13, 2010 | Life Fitness 9100 Next Generation...
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Hi i have life fitness 9100 hr. it is not starting..after inter your weight..it shuts off
    Could be a number of reasons - first to check would be the small micro switch behind the red "stop" button. these sometimes go faulty and will reset the machine at data entry
    Mar 02, 2010 | Life Fitness 9100 Next Generation...
    Refilled with wax how to reset display
    you have to enter maintenance mode, press (CLEAR) and then press the key (PAUSE) there will appear a message that is doing a checkup, then using the keys you move up to find "Maintenance" and press enter Ahi provided with keys look for the option "WAX REFILL" press "ENTER" and ready and be 100% if you have any additional questions here's my e cardiotech_me@hotmail.com
    Feb 16, 2010 | Life Fitness 9100 Next Generation...
    How can i enter in manufacturers configuration menu on Lifefitness treadmill 97ti
    To enter the Manager's Configuration, press and hold down the PAUSE key and press the
    CLEAR key twice. Continue to hold down the PAUSE key until the MESSAGE CENTER displays
    the words “SERVICE MENU”. Then, release the PAUSE key, press the QUICK START
    key, and press ENTER. The MESSAGE CENTER then displays, in turn, each of the configuration
    settings.
    Jan 14, 2010 | Life Fitness 9100 Next Generation...
    Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
    307 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
