Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My trinitron tv has no audio? maybe it is the tv settings?
Trinitron tv won't come on. says please wait
There may be a issue with the tuner on the set but there is a way around that.
With a cable box with audio/video out jacks connect to the same kind on the rear of the set---go to that input on the set and should see picture and sound---leave set on that input and change/select channels with the box.
Nov 02, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY TRINITRON Model KV2197PF2 have no audio video is ok.
only a few things to check here:
First is does it work when a DVD player is hooked via the audio and video jacks?
Look in audio menu in the set to see if speakers are turned OFF or ON.
Look on the set and a cable or sat box if used that volume is not down or muted.
failing all these the set has a audio problem.
Apr 24, 2012 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
I also have a 27 inch Sony Trinitron and only nget
Just for the heck of it, check to see if the SAP setting is correct in the Audio selection menu. It should be set to Stereo.
I hope this helps,
Skyassoc
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron TV sap button got pressed and don't know how to take it off
You should be able to find the SAP, Normal Audio option in the Audio Set-up or Options sections when you select Menu.
Aug 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No volume--tv reads "volume isfixed
You need to go into the Sony menu and choose the audio setup. Unchoose the volume fixed setting and you will get audio back in your tv set.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron turns on in the middle of the night for no reason
maybe the people next door have a powerful remote, and when they turn their tv off a night it turns yours on?
Dec 11, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony TV Repair
crt going bad it is a common problem on sony old sets
Aug 06, 2008 | Televison & Video
Can't hear voice/some audio
your audio setting is set to 5.1 and your do not have enough speakers to hear all the sounds. I suggest to change the setting to 2 speakers and you will be able to hear everything. good luck
Apr 03, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
"sony trinitron" sound problem
because you t.v is set on the audio output... out .. setting again the the audio output off will result the problem .. the sound will come from the t.v. instead of the speakers output
Dec 06, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Oct 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
