Question about Haier HLP21E Top Load Washer
Is there a hose extension I can buy? my sink faucet is just a hair shy of the machine nozzle. It would be ok if the appliance had wheels but it doesn't. it's kind of hard for me to push it. If I had a longer hose it would be perfect. —d
  • Haier Master
  • 43,501 Answers
You should be able to find hoses upto six feet long... if that is not long enough then there are hose connectors that will connect two hoses together...your local hardware or a big box like HD or Lowes will have the connectors...they have hose thread on both ends and adapt the two female ends of the hoses together...
heatman101
Posted on Aug 07, 2010
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
I can't turn faucet from one kitchen tub to other and hose is difficult to pull out
Look under your sink. The house is caught on something like your drain or something under the sink..
Jun 02, 2012 | Moen 7840 Camerist Single-Handle Kitchen...
The hose head keeps falling away from the unit. It should stay pushed in
Has no hose weight or not heavy enough weight on hose under sink. either buy a weight and install on hose about 18" from the bottom of sink. or you can use a 3 ounce fishing sinker with bread tie and tie it around hose aprroximately 18" from bottom of sink. It needs the weight to keep the faucet head in.
Aug 31, 2011 | Grohe Plumbing
I want to install an RO unit. For the RO faucet connection I would like to use the air gap connection on the sink that connects to my GLD5960 SS dishwasher. Can I get rid of the air gap connection from...
The airgap prevents the water from the sink backflowing into the dishwasher. You could espically if your dishwasher hasa corragated plastic drain hose attach it under the sink so at one point the hose is higher that the nozzle of the disposer it connects to so the hose is still higher that the level of the nozzle and water wont backfill into the dishwasher.
Gene
Aug 09, 2011 | GE Dishwashers
My Blanco Torino faucet is leaking under the button when you press the button on top to use the spray.
Check the hose connections at the spray head nozzle it sounds like it is leaking there and running down the hose and ending up under the sink.
Feb 08, 2011 | Blanco Classic Single Handle Faucet with...
Slow flow, spray will not stay on.
you need pressure to make the spray stay on so maybe check the valve under the sink to see if it has turn almost off, that happen when the pull out nozzle gets returned and the heavy weight on the hose hits the hose
Jul 20, 2009 | American Standard Kitchen Faucet 6310 020...
Washing machine drain hose too short
add extension with hose clamps will be fine
May 26, 2009 | Washing Machines
Haier HLP21E Top Load Washer Logo
1,007 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
