Question about Frigidaire Laundry Optional Pedestal APWD15W
I have bracket kits for APWD15W1 pedestal but have the APWD15W pedestal. Is there a way to adapt the brackets that I have for the pedestal I have?
4 Suggested Answers
  • 121 Answers
SOURCE: Using a Wall Air Condtioner in Window
It is called a mounting kit and can be purchased at Home Depot, Lowes, or an appliance store.
Posted on Sep 30, 2008
  • 4 Answers
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
onthejob5130
  • 640 Answers
SOURCE: Installing dishwasher --- what is
no,,the seal that fits on the top snaps on from the front and you have to lift top mounting brackets up than kind of work the two brackets back down,,or you can just unclip the mounting bracket .snap top seal than than put brackets back,,clip hold the seal down some,,,those side and top seal are mostly to stop a person from cutting ther hand if unit is pertruding a little...now to make dishwasher reach the counter when legs are down all the way..get to peices of wood the lenght of unit front to back just short of front toe panel..i cant help with thickness because you have to measure the gap from counter,,some times i find that the wooden slats that came with the dishwasher works great...good luck..anymore ideas needed just repost
Posted on Sep 09, 2011
Can I use a frigidare pedestal model number apwd15w fit on a kenmore model number 41122
Good Morning Kristy, thank you for your question!
Because pedestals are designed specifically for the manufacturer brand appliances, I am unable to guarantee it is compatible for installation with a different brand as the dimensions and other specifications may vary.
Best regards!
Dec 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallery remove pedestals
There should be a bracket on the front and back of the pedestal with screws going into the bottom of the washer or dryer. Many times it is inset so you do not normally see it. Remove the screws in the bracket and it should come right off.
If you do not have brackets it might be screwed in from within the pedestal body in which case you would have to take out the drawer to get to the screws.
May 19, 2012 | GE WBVH6240F Front Load Washer
Hi - I would like to mount my monitor on the wall - can I salely cut just below the power input?
Most monitors allow for a wall mount to be screwed on to the back with a standardized kit. I would not cut anything if I were you. Just disconnect the pedestal and use a wall bracket.
May 12, 2010 | LG Flatron L1715S 17" LCD Monitor
Installation instructions for a Glacier Bay Westminster pedistal sink
Things You'll Need:
  • channel lock pliers, mini tubing cutter, tubing cutter for 1 1/2" tubing razor knife, 24"level drill, 3/16"dia. drill bit
  • 3/8" drive ratchet and sockets, tape measure, Teflon tape, 8" adjustable wrench, black sharpie, small edges (cedar wood shakes) 3/8"x 3" anchor bolts, pedestal sink, faucet with pop up drain, P-Trap,
  • sponge, rags,
  • lavatory supplies
The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
  • Step 2 The drain for the sink needs to be set just right so that the finish work will go together easier. When setting the drain make the threads for the trap adapter stick out just past the finished wall. If the threads stick out to far then the escutcheon will not fit up tight to the wall. So check the depth of the trap adapter threads before putting the sink in place.
  • Step 3 Press the small foam pads adhesive side down on top of the pedestal. With the faucet and pop-up drain mounted on the basin place the basin on top of the pedestal. Move both pieces together up against the wall with the drain centered with the sink. Check the pedestal for level. If it is not level use the cedar wood shakes as wedges to make the pedestal level. Don't cut the cedar shakes yet this will be done later. Now adjust the basin to make it level as well. With the sink centered and level mark the points where the anchor bolts will go through the china into the wall. Many pedestal sinks come with a wall mounting bracket if yours does then slide the bracket up under the sink and make it tight up against the wall and the china. Be careful not to move the basin, if you have someone to help you have them hold the sink in position while you're doing this. Now mark the holes in the bracket where the anchor bolts will hold the bracket to the wall.
  • Step 4 Move the pedestal sink out of the way. Use the drill with the 3/16"dia. drill bit to drill pilot holes on the marks that you made. Next screw in the anchor bolts into the pilot holes. Make the wall mounting bracket tight to the wall. The anchor bolts that go through the china need to be removed.
  • Step 5 Take the lavatory supplies and wrap the tops of them with Teflon tape. This will create a gasket like seal. Attach the supplies to the bottom of he faucet. Make sure to get a good tight connection you don't want these to be leaking later on. Next take the J-bend portion of the P-trap and slip it on the tailpiece of the pop-up drain. Measure the height of the center of the drain where it sticks out of the wall. With the basin sitting on top of the pedestal put the p-trap together and make the trap arm the same height as the drain pipe. Mark the top of the J-bend on the tailpiece so you have a reference mark. Next take the basin off of the pedestal and tighten the slip nut on the J-bend. Make this connection secure it will be very difficult to get to this connection later on.
  • Step 6 Move the pedestal into position and set the basin on top of the pedestal. Check the small adhesive pads if they have fallen off stick them back in place. Line up the holes in the china with the holes in the wall and screw in the anchor bolts. Don't tighten these yet you still have to adjust the basin and level the pedestal. Put the cedar wedges back in place to level the pedestal and adjust the basin. Now that everything is level tighten the anchor bolts. Be careful not to over tighten the bolts they could crack the sink.
  • Step 7 Use the tape measure2_bing.gif and measure from the center of the J-bend opening to the trap adapter. Add about 1 1/4" to this measurement so some of the trap arm will be inside the adapter. Cut the trap arm to length with the tubing cutter. Next slip on the slip nuts and washers and don't forget the escutcheon. Install the trap arm. Catch the slip nuts with your fingers and tighten as much as possible by hand. Tighten the rest of the way with the channel lock pliers. You'll notice the first nut on the J-bend is almost impossible to get to that is why you must tighten it before you set the sink.
  • Step 8 Take the lavatory supplies and gently bend them to line up with the supply valve connections. Now mark the supplies where they will fit into the compression joint on the valves. Use the mini tubing cutter and cut on your marks. Slip the compression nuts and ferrules onto the supplies and put the supplies into the valves. Catch the nuts with your fingers and tighten by hand. Now finish tightening with the adjustable wrench2_bing.gif.
  • Step 9 Remove the aerator from the spout of the faucet. Turn on the hot and cold supply valves and run the water in the sink to flush out the lines. When the water runs clear put the aerator back into the spout. Close the pop-up drain and fill the basin with water. While it is filling check underneath the sink for any leaks and repair them if necessary. When the basin is full open the pop-up drain and let the water out. Check under the sink once more for any leaks and repair them.
  • Step 10 Use the razor knife to cut off the excess cedar wood that sticks out past the china on the pedestal. Next caulk around the base of the pedestal where it meets the floor. Also caulk along the top edge of the basin where the basin meets the wall. Dampen the sponge and wipe off the excess caulk to make a smooth caulked joint. Clean up and admire your handy work.
  • Mar 30, 2010 | Pegasus Technologies Home
    How do I replace the bath sink stopper lift using a Danco universal kit
    Things You'll Need:
    • sponge, rags,
    • lavatory supplies
    • Step 1 The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
    Mar 30, 2010 | Home
    Try to mount TV to the wall and need to release the TV stand
    To Display your LCD TV using a Wall Bracket:
    If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
    37HL17: 46.3 lbs (21.0 kg)
    42HL17: 59.5 lbs (27.0 kg)
    1) CAUTION: Two people are required for installation.
    2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
    3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
    4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
    Removing the Pedestal Stand
    1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
    2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
    3) Remove the five screws. This will allow removal of the pedestal stand.
    4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
    Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
    Oscillating bracket broke, need to replace
    Please suggest where I can buy a new blade for 16' airworks pedestal oscillating fan?
    Thanks... VladF
    Email frolovvl@sympatico.ca
    Phone (home) 905-891-5741
    Phone (cell) 416-471-1326
    Aug 31, 2009 | Optimus F-1660 Fan
    Installing pedestals for washer and dryer
    its not but it is a 2 person job, the washer is in excess of 200 lbs and must be lifted onto the pedistal, after that its just a few brackets and philips screew to secure it.
    Feb 07, 2009 | Kenmore 15.5 in. Pedestal
    Broken bracket on lasko pedestal fan
    I have the same problem. Called Lasko parts department and got one. http://www.laskoproducts.com/
    Description of part on invoice - 05098021T BAG HDWR BASE T/BLK 30PTEXTURE BAG
    Cost $7.50 for part plus shipping to me was at $6.61 so it was pretty cheap. Comes as a package with four screws/washers/nuts. Hope this help someone out there.
    Sep 08, 2007 | Lasko 3135 Stand (Pedestal) Fan
    Washing Machines Logo
    43 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
