Question about Kenmore Refrigerators
Old coldspot isnt working right. The bottom of the freezer side blows cold air but the top doesnt and everything is thawed up top.The fridge is warmer than normal and I think itd getting warmer. This just started today. Any ideas would be great...thanks
  • Kenmore Master
  • 43,501 Answers
Sounds like the old faithful just developed a freon leak...
hold aceromony for the old girl and say goodbye... :-(
heatman101
Posted on Aug 07, 2010
  • ryacwazy Aug 08, 2010
    or maybe its the evap fan motor? If it is still blowing cold air somewhere that means their is not a freon problem. Therefor that means the compressor is still working. It sounds more like there is a cheaper sollution to the problem. Evap fan motor if there is no air blowing up top. Cost bout $60 and easy to replace. Better to spend that than $500 and up on a fridge.
  • D. Floyd Kolb
    D. Floyd Kolb Aug 08, 2010
    You stated that it was still blowing.... therefore I assumed that the fan was still working...
    yes if the blower is not working, check it out for power and replace it if it has power but is not running....
    However,
    low freon can also make some cool air but not enough to completely cool just as you described...
    I gave you just what my forst thought was from what you described and my experience with these things...
    heatman101
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
Freezer works now and fridge still warm
your right the air is not getting through the cold coil / when you defroated it . did you remove the back of freezer . if not there is still 2 in of ice back there blocking the air flow/ now a good defrost is needed but you need to correct the problem of why this happened . either the timer / heater or defrost termminator is bad . usualy its the heater.. mm hope this helped .. feed back pls
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
