Tv turns on, picture disappears after a few seconds, turn off tv, and then on, same problem picture is fine, the disappears after a few seconds
Sony KDFE55A20 turns on then after a few minutes sound and picture disappear only to come back on then off...continues this cycle until I turn it off. Power light stays on. Have tried checking power supply that is not it. What else could it be?
Posted on Jul 18, 2011
  • 11,361 Answers
You may have either failing 24vdc power supply or the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
My Vizio E65X-C2 Tv will turn on and show a picture for a few seconds then the picture will disappear. Back lights are still on. Can;t turn TV off with remote or power button have to unplug it
This sounds like a bad FET on the main board, change that board and that should fix it, or if you have the test equipment fix it yourself
Nov 04, 2017 | Vizio Televison & Video
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV signal disappear after after a few seconds.
You can get a replacement U board at the following link which is most likely the problem as the U board has all the input sources on it. Look under the Sony parts category for the U board. They have the one for your model
http://servicemanuals.vstore.ca/
Apr 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture Disappears with in seconds after powered
picture disappear and appear again after few seconds.this is repeated again and agains
Apr 04, 2009 | Hisense TA42P40M 42 in. Plasma Television
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Televison & Video Logo
660 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
