Question about Pentax Cameras
I dropped my Pentax Optio 33LF yesterday, It was working fine when I turned it back on to see if there was anything wrong. After that I've turned it back on and off about 6 times, the batteries were starting to die so I turned it off. And now whenever I turn it on it makes a loud buzzing/error noise after I turn it on, shows picture then it turns off.
  • 26 Answers
Lens problems , need replace the lens or fix the lens very easy to fix that lens ,
Posted on Nov 01, 2017
Quack
  • 542 Answers
SOURCE: 256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Posted on Sep 08, 2005
SOURCE: pentax optio s5i
Hold the OK key for 5 seconds while powering on the camera. this unlocks the menu and key modes.
Posted on Dec 04, 2007
SOURCE: Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Posted on Apr 12, 2008
SOURCE: Camera turns on, beeps, turns off.
I've managed to fix my camera - but it took several hours and I needed someone to help. Not sure everyone will want to do this.
Here goes:
Need small Philips screw driver. Pair of tweezers for the small screws. A small flat screw driver for leveraging
1. Remove the battery and memory card.
2. Remove wrist strap
3. Take off the battery cover by gently lifting the retaining metal strap (with small flat screwdriver).
4. Remove all screws of the front cover of the camera housing. (one of the screws is smaller than the others). There's a screw above wrist strap loop.
5. The top of the cover is clipped in under the shiny silver bit with the on/off switch and shutter button (I’ll call it the switch/speaker assembly). I find that inserting a finger nail and gently applying pressure works well.
6. The switch/speaker assembly is best kept secure by an elastic band.
7. Verify the problem is the same: looking into the lens, at bottom right corner of camera is a small motor (silver). Look carefully, you’ll see a white plastic gear which connects the motor with a (hidden) pink gear. This pink gear is attached to a worm gear (a pin with a fine screw thread) that is brass/golden. On this worm gear is a U-shaped blue piece of plastic, which in my case was no longer at right angles to the shaft/worm gear. That's the problem.
You should be able to see all of this under a strong light and peering into the little openings.
8. Resist the temptation to just fix this by leveraging the blue rider with a tiny screwdriver (or something) until it is back in its original position. You might strip the screw thread inside the blue rider and that would be the end of the camera.
9. Next take the LCD display off. Above the little motor is a metal clip attached with 2 screws hidden behind self-adhesive copper strips.
10. Fold the LCD panel away from the camera body. Then carefully and gently unplug the power plug (pink & white in my case). Careful, the green PCB (printed circuit board) to which the socket is attached is flimsy. I don’t think it can take much force. Rather try to pry the plug & socket apart by using a knife or tiny flat screwdriver?
11. With the power cable removed, you can turn the LCD panel over (anti-clockwise) to undo the fold that is in the flat cable. The flat cable is attached to a small white plug on the PC board that contains the rear panel buttons of the camera. There is a thin, orange plastic sheet stuck over this. Lift it away gently and store somewhere for later re-assembly.
12. The socket for the flat cable has a black flap that can be lifted to release the cable. Gently tug the flat cable out of its socket and you can put the LCD panel aside.
13. Remove the metal plate that covers the rear of the lens assembly. First remove the two small screws, then unclip it at the bottom and on the side.
14. CAREFUL: in the centre of the lens assembly is the CCD (charge coupled device). This is the “thing” that contains 7 Megapixels and takes the pictures. NEVER TOUCH THE FRONT OF IT (or so I have read – I think it prudent to observe this.
15. Remove the 3 screws that hold the CCD in place. It needs to be lifted vertically from the lens assembly, otherwise it gets stuck. NOTE that my camera had two small washers under the CCD assembly: top right screw = copper, bottom screw = silver washer. The CCD assembly, too, is attached with a flat cable. The socket works exactly the same as the LCD display. I put my CCD assembly into my glasses case to prevent it from getting dust or dirt on it.
16. Now remove the 4 screws that keep the rear cover of the lens assembly attached.
17. Before removing the cover, unhook the little metal spring that is attached to the mechanism next to the worm gear. Take it right out, feed a bit of thread through one end (for re-assembly) and put it aside. (If you attach the thread immediately, the risk of losing it is reduced.)
18. Then, using your finger nail gently unclip the plastic hook next to the worm gear and lift the lens assembly cover off. There is a long plastic pin so you need to lift it quite high. Observe how the pink gear is situated relative to the plastic mechanism crossing the lens assembly. Remove the pink gear/worm gear with the blue “rider”. Be careful not to lose the small white gear that makes the connection to the driving motor.
19. Unscrew the blue “rider” from the worm gear. Ensure you keep the same orientation and gently find the correct way of putting it back. That is at right angles to the worm. Leave it fairly close to the end of the worm gear away from the pink gear.
20. Now put it back carefully. Try not to lift the part that crosses the lens assembly (the one that was attached with the little spring) too much. Otherwise a little lens flips down and you’ll have extra work to put it all back correctly. There is also a pin on which the plastic piece rides which then needs guidance when re-assembling. (Happened to me, not the end of the world.) (BTW, I think this is the auto-focus mechanism, but I can’t be sure.)
21. Hook the spring over one of its attachment points. Feed the thread through to the other side and use it to hook up the other end of the spring. Cut and remove the thread.
22. Replace the rear lens assembly cover. The long plastic pin needs to find its corresponding hole near the middle of the lens assembly. Remember the hook at the worm-gear corner. Do that one last (after the screws), ensuring that all gears and shafts/pins are in their respective holes.
23. Put back the CCD. I attached the flat cable first (flip down the black locking lever on the socket), then put in the screws. (Remember the washers.)
24. Now put back the metal plate. Clip it in on the left side first, then at the bottom, then the screws.
25. Attach the LCD flat cable. (Remember to lock the socket.) Flip it over and attach the power cable to the LCD. Remember again to be careful with the plug & socket since the PCB is flimsy. Try to apply pressure only on the plug & socket.
26. Replace the orange plastic that covers the electronics.
27. If you like, try out the camera to see the effect of the repair. I used an elastic band to keep the LCD and switch/speaker assembly in place. The battery can be inserted as per normal. NOTE: Where you observe the little blue rider in its installed position, there is a plastic pin sticking up towards the front of the camera (just under the lens). You have to hold something over this hole to prevent the pin (which is being pulled up by the little spring we removed/replaced earlier) from coming up too far. I held my thumb over the hole. If you don’t do this, you camera won’t switch on properly or won’t focus correctly. (In normal operation the front cover stops the pin from advancing too far.) Now switch on and see that all is in order. Careful when operating the zoom and other switches, since you don’t want to break the plastic covering of the switches.
28. If all is OK, then finish the assembly. REMOVE the battery! Next is the little metal plate that keeps the LCD panel in place from the side of the camera. (Remember to flatten/re-attach the adhesive copper strips.)
29. Clean the LCD panel and inside of the rear cover very well. Then put on the back cover.
30. Attach the front cover, clipping in the top carefully. Be careful to position the speaker/switch assembly properly. There is a tiny locating pin (made of plastic) - don’t break this.
31. Put back the screws all around the camera housing. Remember there is one smaller screw that fits underneath the lens. Remember also the screw just above the wrist strap loop.
32. Slide back the battery compartment cover onto its metal strip. Insert battery & memory card. Attach wrist strap. Done!
Stephan
Posted on Jul 12, 2008
SOURCE: My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Posted on Nov 18, 2008
Pentax Optio 33LF Digital Camera
This camera accepts a 512 mb sd card maximum. If you try 1 GB or bigger, takes a couple of shots and freezes.
Mar 08, 2013 | Pentax Optio 33LF Digital Camera
When I put my 2gb Sandisk memory card in my pentax optio 33lf, it turns on, the lens goes out, it takes a photo and freezes. What is the problem? If I take the memory card out, it works fine?
My 33LF won't work with even a 1gb Memory Card. It freezez up as you describe.So far it seems happy enough with 512mb cards. A camera shop operator told me that the capacity of the card exceeds the capacity of the camera and it seems he was right.
Jan 08, 2011 | Pentax Optio 33LF Digital Camera
How do I upgrade the firmware on my Pentax Optio 33LF? Camera goes crazy. Does not recognize any more my SD card (2 Gb)and I'am afraid to loose the photos. I hope if I upgrade the firmware ( vers...
According to the Pentax web site, there is no firmware update available for the 33LF camera. As far as your pics are concerned, you can use a card reader to download them to your computer. Then, you can format the card in the camera and everything should be ok.
Jan 09, 2010 | Pentax Optio 33LF Digital Camera
My camera freezes
This camera supports only 512 mb sd card. If you use any bigger, it freezes. Tried with 1 gb and 2 gb and freezes, while 512 is just fine for the size of the pics of this baby.
Jul 22, 2009 | Pentax Optio 33LF Digital Camera
Why no sound?
I have a pentax optio 33lf, and indeed it has video, but with no sound. I have no idea why they chose not to build a mic in the camera bat the fact is thet it films, but with no sound. so don't even bother trying to find a solution because ther is none
Sep 26, 2007 | Pentax Optio 33LF Digital Camera
Won't turn on at all
My Optio 33LF gave the same "card not formatted" message and then shut down completely at a family party.  I took it to the Pentax Canada depot which is nearby and the technician said the main circuit board was gone.  A C$130 part + labour estimate = time for a new camera !
Sep 17, 2007 | Pentax Optio 33LF Digital Camera
Optio 33LF LCD problem
This often indicates a card error. Transfer all your images then format the card in the camera. If you still have the problem, try a different card. If you still have the problem then looks like you will have to send it in for repair.
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Cameras Logo
63 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
