Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The motor is running but the chain isn't moving. Any suggestions?
    President:
  • 3,197 Answers
Remove the cover from the motor unit and check the drive gear. I'm sure you will find what looks like white sawdust all over and the gear will be stripped. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Posted on Aug 07, 2010
Nordictract treadmill motor runs but belt won’t move. Will move manually.
Sounds like the drive belt isn’t attached. Are you sure the motor is running?
Jan 22, 2018 | Exercise & Fitness
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
My e300 razor run but will not move
Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
Aug 12, 2014 | Razor E300 Scooter
My stanley garage door opener motor runs but it won't open or close my door
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Jul 27, 2010 | Digi-Code Digi Code 5202 Garage Door...
Garage door chain isnt engaged. motor is running
SOUNDS LIKE A BAD GEAR KIT
IF THE CHAIN MOVES BUT THE DOOR DOESN'T IT WOULD BE THE TROLLEY RELEASE. IF THE CHAIN DOESN'T MOVE IT WOULD BE THE GEAR KIT.
HOPE THIS HELPS
Jan 03, 2010 | liftmaster Chamberlain Garage Door Opener...
The motor on my Genie Chain Glide garage door operator runs but the chain does not run or move.
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Dec 29, 2009 | Genie Company Genie PowerLift Excelerator...
Motor runs but chain does not move?
Check the chain drive sprocket to see if it moves when the motor runs. If not, there may be a sheared key between the shaft and sprocket or the teeth on the sprocket are badly worn off. Hope this helps!
Dec 22, 2009 | Garden
Just got MCC4516F chainsaw.Used it for 30 mins. Stopped working. Chain brake does not engage or release. Chain does not move. Motor runs but will not engage to make blade move. Seems like chain brake...
You have obviously jammed or broken the chain on the inside of the motor. Take it to be repaired, or try reparing yourself by opening up the engine casing yourself.
Nov 19, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Craftsman opener motor works, but chain does not move.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Won't Open
When mine did this, it was because the nylon gears that drive the chain had stripped. My wife had to live without the opener for a week or more, but I was able to find a new gear kit online and replace the damaged gears. It wasn't difficult.
The other option is to buy a new opener.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
76 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
