Question about Saws
After the log is squared on my sawmill i saw the lumber and it becomes thicker on one end,than the other
  • 43,501 Answers
You hit something on one side of the blade and now it wants to saw crooked...you either need to resharpen the blade or get a new blade...
heatman101
Posted on Aug 07, 2010
I can hear the motor working however the blade got stock when I'm cutting the wood, does any one here know what to do with that type of issue?
If you are using a circular saw, you are probably ripping hardwood lumber that was originally sawed (incorrectly) under stress. Back your saw out and start the cut again. You may have to do this several times until the lumber "relaxes" enough to be cut.
Nov 30, 2017 | Blade Saws
What husqvarna chainsaw model will be compatible for a portable alaskan sawmill?
you will loose 4 inches off bar in the clamp of your Alaskan saw mill ( I have one too and use it to make carving blocks) so your bar will need to be long enough to go thru your log plus those 4 inches , I actually have one special bar/chain that ive drilled all the way thru to mount clamp with so it cant slip , but I will caution you , saws over 19 inches require a heavy hand to operate and will require a bit more strength of the operator , this will tire you out on long cuts , if you stop in middle of log ,there will be a mark there in final cuts that will need to be sanded away , also use long drywall screws with drill to secure your track down , not nails that way it wont move easy to mess up your cut , and last but not least , watch your chain oiler , most don't work too well pointing down , and keep your chain sharpened too makes for less effort from operator
Mar 17, 2016 | Husqvarna Garden
Lumber wiring diagram
Lumber - a piece of wood , wiring diagram ! would you like to try again ? I know for a fact there is no lumber wiring diagram on a 1999 Cadillac Deville !!!!!!!!!
Apr 19, 2015 | Saws
Not getting true cuts on sliding miter saw.
Sounds like the blade isn't parallel with the sliding mechanism.
Oct 24, 2014 | Saws
I need track layout for Thomas log mill
Ok well from that description I'm assuming that you are talking about the zip zoom and logging adventure from the trackmaster company, you could probable just search that in google and I'm pretty sure the track plan will come up. I have the same set and if you can't find the instructions online, I'll see if I can find my instructions somewhere.
Jun 18, 2014 | Tomy Thomas The Tank and Friends Track
What is Quarter-Sawn Lumber?
Quarter-sawing is a method of milling trees into lumber. Quarter-sawn lumber is highly sought after, particularly in certain species such as oak or maple, where look of the grain in the wood is accentuated by the method of cutting the tree. While rip-sawing is the most efficient (and common) method of milling, quarter-sawing is more difficult to cut but yields much more stable lumber. Because it is more difficult to cut and there is more waste, quarter-sawn lumber is considerably more expensive than rip-sawn material.
(taken from http://woodworking.about.com)
Feb 27, 2013 | Crafts & Hobbies
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Saws Logo
73 people viewed this question
Top Saws Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
