Question about Acer Aspire™ T180 PC Desktop
Computer beeps when turning on and wont start up
  • joecoolvette
    joecoolvette Aug 07, 2010
    As semi referred to, the beeps you hear are BIOS Beep Codes. The computers way of telling you something is wrong, and an area to start looking in for the problem. BIOS = Basic Input/Output System. A small program that is usually 64KB in size for a desktop computer. BIOS is the first program to start up, when you start your computer. BIOS will look to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System. (Windows XP is one example of an O/S) There are several manufacturers of BIOS. Two of the main manufacturers at present are Award/Phoenix, and AMI. When a pre-built computer is manufactured, the computer manufacturer has a BIOS manufacturer make a BIOS for THAT series, or model line of computers. Therefore THAT BIOS is made for THAT computer. That particular BIOS has it's own set of BIOS Beep Codes. The beeping you hear, is as stated, a Code. May be one Long beep, followed by several Short beeps, for example. Could be three Short beeps, for another example. You could compare it to Morse Code. What is the beep code you hear? Listen closely. Listen for a repeating pattern. It will beep a few times, then completely stop. Then the beep code will occur again. Need to know what beep code you are hearing.
    Scholar:
  • 50 Answers
Http://www.computerhope.com/beep.htm
Its kind of hard to tell just by one beep but the site listed above will give you codes to associate with your beep and then see if any matches and the solution beside...
hope this helps...
Posted on Aug 07, 2010
Computer starts to power up, two beeps then nothing and wont come on
severe virous you may need to format and reinstall all softwear.
Sep 18, 2012 | Gateway One Computers & Internet
Computer wont start.
I don't have access to your board details. However, beeps frequently represent memory problems. Try
removing the memory on your system and then putting it back.
You can access your memory on the bottom of your computer. It is likely the smallest rectangular hatch. After powering donwn the computer, remove one or two screws.
Remove the memory sticks by spreading the clips on each side of the memory. After removing them, put them back. This will clean the terminals and ensure a good connection. Before putting the back on, try to boot the computer. If you hear no beeps, all is good. Turn off the computer and put the hatch back on.
If you hear beeps, switch the memory modules. Try again. If you still hear beeps, try one module at a time in the primary memory slot. If one of these works, you should be able to buy a new memory module. Go to a sight like Crucial's and have it tell you what you can add. Perhaps this is a good excuse to upgrade.
You should do this at the kitchen table to avoid any static discharge.
May 20, 2010 | Fujitsu Siemens Lifebook N5010 Notebook
MY COMPUTER WONT TURN ON AND MAKING A BEEPING NOISE
beep noise indicates that the RAM is not detected.... TURN OFF computer....remove power supply....open the cabinet and remove the RAM.... clean it using a soft non-moist cloth...plug it back.... your computer will start... still if it is not starting, then the RAM might have gone faulty, try to check with other RAM.....
Apr 28, 2010 | Compaq CV 7500 17" CRT Monitor
Emachine T5062 pc wont turn on, I get 5 beeps When the computer performs the ''Power on system test''. I could not remember what BIOS the computer had but I think It was AMI. The five beeps for AMI mean...
make sure it is not getting really hot, also try cleaning all again and start putting them together step by step. make sure the dust didn't got in another part like RAM memories slots, and if you have a big problem with the processor the PC wouldn't even start, wont even turn on.
Nov 15, 2009 | E-Machines eMachines Desktop PC
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
Computer wont start
The beep codes are related to hardware issue with your computer. Could be the RAM, video card or the motherboard. However to help you better, we would need to know the model number of your computer and preferrebly the BIOS manufacturer
May 30, 2008 | Computers & Internet
Wont turn on, bios beep code
Seems heat-related motherboard POST failure. Replace it.
May 25, 2008 | Sony VAIO PCV-V210P PC Desktop
Acer Aspire™ T180 PC Desktop Logo
659 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
