Question about Seiko 0512039FA Wrist Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I have a Seiko flight watch, blue face, stainless band. The Chronograph second hand no longer resets to the 12 oclock position. It started dropping back by a second a week until it hit the 11 mark. I have had the battery changed as someone suggestd that was the problem, still no change. Now it is resetting to the 6 oclock position. How can I change where it resets too??
  • david2132 May 06, 2008
    I have the same problem with my seiko chronograph. The second hand resets about 2 seconds after 12. It seems very strange
  • Anonymous Sep 07, 2008
    my seiko chronograph with the 7T62A movement no longer resets the sweep second hand to the 12 position but stops it at the 25 sec position,am going to manually stop it at the 12 spot then remove and replace the battery to see if that fixes it.
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Posted on Jan 12, 2009
  • Rick Eddington
    Rick Eddington Dec 04, 2012
    Thnx It took about 7 or 8 times before it worked.
Pull the primary bezel out as if setting the clock hands. Push the upper left button and it will change the sweep second hand to wherever you want it
Posted on Sep 18, 2008
  • 37 Answers
Pull out the knob that you adjust the time with to the second position (2 clicks) leaving knob out push the top button on the opposite side and hold down, the second hand will advance let up at the desired spot then push the adjusting knob in.
Posted on Feb 22, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
Posted on Jan 05, 2009
I have a seiko with yellow face and 3 blue dials can i change the face at a reasonable cost as the yellow makes it hard to quickly read !
Posted on Mar 23, 2009
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Seiko 0512039FA Wrist Watch Logo
5,791 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
