Question about Beverage-Air 23.1 cu. ft. / 654 liter Commercial Freezer BEVEF-24S
The motor run for about 5 second and stop, it keepe doing that since this morning. what should I do?
  • Beverage-Air Master
  • 43,501 Answers
You probably have a freon leak and the compressor is cutting out on low pressure.... then it stops... the pressure builds and it starts again... it will kill it's self doing that...get it serviced right a way...
heatman101
Posted on Aug 07, 2010
I have a Kenmore 5 cu ft freezer that won't come on. I've tested the power cord and that's not the problem. Where should I start looking?
Make sure that power is reaching the motor after going thru the thermostat.
If juice is there replace the starting capacitor. If the motor gets hot but still does not run the rotor might be frozen - check with ammeter for abnormal current draw.
If compressor is frozen all you can do is replace unit.
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Stopped freezing
if the engine (compressor motor) is running but there is no cooling, most probably there is no more freon gas in the system... please refer to refrigerator technician
May 08, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have a servis fridge freezer m7873.yesterday morning the motor became very noisy.by late afternoon it stopped altogether,and everything began to thaw.what do you suggest?
that motor noise if it is the compressor is not a good sign. You will need a service tech to inspect it to make an educated decision on what to do next. I would replace the freezer if it would be cheaper than the repairs
Nov 24, 2009 | Freezers
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Compressor starts then stops after 5 seconds
Installed hard start Kit for this little freezer. No help. Needs new compressor.
May 28, 2009 | Freezers
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Beverage-Air 23.1 cu. ft. / 654 liter Commercial Freezer BEVEF-24S Logo
98 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
