Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
My dad has not used his Jazzy for about 8 months and it only comes on when plugged in and not when it is not plugged in. What can I try?
    Novelist:
    Champion:
  • 232 Answers
Most likely the batteries have gone solid while it was sitting unused. The gel in the batteries requires them to be put on a charger at least once a week even if the rider is not using the chair otherwise the batteries will go bad. Replace the batteries and that will most likely solve your problem. If his insurance bought the power chair for him, they may cover the cost of the replacement batteries. The batteries cost $75-$120 otherwise, and you will need two of them.
Posted on Oct 20, 2010
What is the torque specification for the drive shaft to wheel hub nut on my mom's Jazzy?
Hi this happens with a lot of scooters u could try some LOCKTIGHT unsrew the nuts put the locktight on & tighten them up I use a 2 foot socket bar to tighten them ....good luck
Dec 15, 2015 | Pride Jazzy Select Gt Scooter
Can the batteries or my charger be bad on my Pride Jazzy 1113 ATS?
The MK batteries are far superior to Interstate batteries overall.
You can load test the batteries to see if they are working properly with a load tester. Your can test the charger output to the batteries with a digital voltmeter connected to the batteries with the charger plugged in. These 2 tests take less than 10 minutes and can be done at a local auto or scooter shop for nominal expense.
Make sure the charger and battery connections are tight and free of corrosion. On the VSI of the Jazzy 1113 there is a notorious problem with 8 pin connector and 3 pin molex at the back. You can clean these connectors but a complete electrical rebuild of the pins and receptacles is sometimes required if significant corrosion has set in. Try spraying electrical cleaner and use green Scotchbrite to clean the metal tabs on the 8 pin connector. Make sure the 3 pin molex sits in the receptacle and is making good contact.
Hope this helps.
Jul 22, 2014 | Pride Mobility Products Jazzy 1113 ATS
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
Jazzy 1120 changing controller type?
The 1120 usually comes with either of 3 different controllers: Pilot, Remote Plus or Europa. They function similarly but the setups are a bit different.
Apr 02, 2013 | Pride Mobility Products Used Jazzy...
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
My dads Jazzy 600 got wet and now wont do anything. no lights at all. what can I do- he needs it daily and we are on fixed income?
If medicare paid for Dad's chair then contact Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare didn't pay for Dad's chair then the cost of a refurbed joystick is still very high about $700 and if the joystick got wet then he'll need a new or refurbed one. Sorry Hope this helps
Apr 02, 2011 | Pride Mobility Products Used Jazzy...
Dad has a jazzy select gt. He is in an assisted living facility and he had it taken from him for several months due to roommate issues. It has been returned to him and facility did not keep it charged....
VB the batteries are too weak for the chargers to pick up. Unfortunately you will have to puchase new batteries. Now since the facility was responsible for not keeping the batteries charged I would ask that they pay for the new ones. Good luck with that. The batteries you need are U1 batteries. If you have a battery warehouse type store near you they should have the batteries or an Interstate Battery outlet store. The batteries should be around $200.00 for two. Try not to get them at a local provider cause they'll charge you more. Hopes this Helps you
Aug 28, 2010 | Pride Jazzy 1113 Power Chair
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
May 18, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
135 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
