Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Garbage disposal seems to work **** water down put when you turn the swich off water come back into the sink fast
  • Ace Hardware Master
  • 43,501 Answers
You have aplugged drain line...
You need to take the drain line apart and see why the water is not going down and remove the blockage...
It has nothing to do with the disposer...
heatman101
Posted on Aug 07, 2010
  • 760 Answers
You have some type of obstruction in your drain. There is enough force to push the water in the drain, perhaps even raising the level up into the vent line. When you switch off the disposal, then it rushes back into the shink. Disconnect drain line and run a snake into the drain.
4 Suggested Answers
rcampsr
  • 90 Answers
SOURCE: garbage disposal doesn't drain
Sometimes what happens is that when they install a garbage disposal the pipe coming out of it ends up being lower than the pipe exiting the pea trap thru the wall under the sink. If it is a dual kitchen sink this is very common. Being lower than the exiting pipe causes water to stay in the bottom of the disposal and not just the pea trap. If you have a side by side sink in the kitchen and the water is backing up in the other sink also then more than likely the pea trap has a blockage. It is not common for the straight line from the pea trap going thru the wall to become blocked, but it does sometimes happen. The biggest cause of this is poring hot grease down the drain. It is just about the point that it cools enough, sticks and hardens plugging the drain pipe.
You probably should have a plumber look at it and make sure everything is running downhill under the sink. The only place that water should set in the plumbing is in the pea trap so that odor from the sewer does not come up into the house. Without actually seeing it, it is hard to tell exactly what is happening. The pea trap is easy to clean, put a really big pan under the trap, make sure you have emptied as much water out of the sink as you can, then with a big pair of channel locks unscrew the two nuts that hold the pea trap in place and let the fluid drain from it, then finish unscrewing it from the pipe. You can then clean it out and check the pipe thru the wall for blockage. When reassembling it, screw it all together loosely and then move the pieces around while hand tightening each joint so the they have no pressure on them, then use the channel locks to finish tightening the nuts. Don't over tighten them because they have nylon seals in them that compress to make the seal. Just tight enough to seal and not leak. You should be up and running again unless the plug-up is farther down the wall pipe. Good Luck, RAC
Posted on Apr 21, 2009
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
wentlanv
  • 710 Answers
SOURCE: Garbage Disposal Ace 2000 model
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 07, 2011
Testimonial: "Thanks for getting back to me and for being very articulate and thoughtful in your suggestions... You did a great job, Handie Andie! David T."
Sink erator
First, unplug the power cord to the "Sink aerator" disposal from under the sink storage area. Next, remove the black rubber strainer from the upper sink area leading down into the disposal. (It simply pulls upward to remove) This will allow you to put your hand down into the disposal area to physically clean out the disposal deposits by hand. Pull out whatever is plugging the disposal and throw the debris in the trash, not back into the disposal. Once everything is removed from inside the disposal, flush it out completely with water from the faucet until it drains freely. Reassemble the black rubber strainer and plug in the disposal once clean. Be sure not to put potatoe peelings and other non-disposable items which can't be ground up easily in the garbage disposal. Keep in mind, just because it says garbage disposal, it doesn't mean all "garbage." Also, always use plenty of water when using the disposal and allow the water to run for a minute or so afterwards to finish washing down the debris in the sink "P" trap drain out through the outer sewer line.
Jul 07, 2014 | Home
Water does not drain from sink unless disposal is turned on and running. what could it be?
It would appear there is a blockage (a clog) in the disposal. You might try "FIRST" unplugging the disposal from under the sink. Put a piece of masking tape over the switch to secure it in the "OFF" position. Then remove the black rubber strainer from sink leading down into the disposal. (just pull it out by hand) Clean out all debris by hand. Put the removed debris in the trash can. Run hot water down into the disposal assuring it to drain properly. Do not put items into the disposal which cannot be ground up easily such as potato peelings and meat products.
Jun 24, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our disposal is full of water, and will not drain down. we had orange peels in there, which seem to not be in there any longer, but the water will not drain out of the disposal. We have a Badger as well.
Take apart P-trap located under sink.
Take photos of everything before starting so things go back easy.
Remove stuff from under sink, get some old towels, and put bucket under sink to catch water.
Loosen both nuts on P-trap and it will fall loose.
Turn on water and turn on disposal for a moment to see if blockage will fall down into catch bucket.
If disposal is still blocked, remove tailpiece connected to side of disposal and then clean out disposal with coat hanger, and/or plastic pipe that is duct-taped to shop vac hose. For a real mess, turn on the water and run disposal to clear blockage while tailpiece is off.
Clean and reassemble parts.
I use rectorseal for all tubular joints so they will not leak.
For re-assembly, I wrote tips with photos from days when I worked apartment maintenance.
Apr 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the...
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Oct 02, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I never put potato peels in but in the 3 months I have owned this house it has stopped up twice. Why?
The problem should really have nothing to do with potato peels. Even a cheap disposer should have no problem chewing up things much worse than that.
There are two main things that could be causing your problem: 1. Defective disposer or improper installation 2. Improper usage of disposer (more likely)
I've been known to put entire sinkfulls of waste down the diposer (mine is an ancient thing from the 70s), and I've had a clog maybe once. You have to be conscious of the amount of water that's going down with the waste. Ideally, before anything solid at all goes down the drain you should turn the faucet on COLD full blast and then turn on the disposer. The grinding mechanism is so fast that the disposer shreds the solids and blows them into the drain pipe at a very high rate. If there's not enough water down there to get thrown down the drain pipe with the waste that's when a clog happens. So don't turn the disposer on AFTER putting a lot of waste down there and always do it with a full flow of cold water. Feed the disposer gradually with the waste and let it run until it sounds empty.
When done right, the worst clogs can easily be dispatched with a plunger in three or four strokes. With a toilet the best way to it make sure the plunger is sealed good and plunger with short, fast, powerful strokes. When you unclog a disposer, the clog is almost always in the connection where the disposer discharges into the drain pipe because of the funnel effect. When you push the plunger down the water pressure will go up but the waste will compact tighter and resist flow even more. You want to push the plunger down and let it leak until you get it as far down as possible, then let it form a good seal and give a powerful upward stroke. That'll create strong suction and pull the clump of waste particles back, where they'll mix with the excess water and go right down the drain. If you don't have a plunger, you'll find that for some reason a soda can will work in a pinch.
Oct 30, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
419 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
