Question about Fisher and Paykel IWL12 Top Load Washer
I have a Simpson eziset 550 5.5kg washer, just got it yesterday I go to do a normal cycle and I press start and it beeps 4 times and the water temp buttons start to flash, then the in progress light comes on. the only cycle that works is the drain and spin, its drains but then doesnt spi
I have the same problem. did you end up fixing it or find out whats wring with it? thanks.
Posted on Jan 09, 2011
  • holdenpride8 Jun 10, 2011
    Me too im looking for a solution too. And its only just out of warranty ha go figure from what I have read on net in the last ten min sounds like they only last 2 yrs and are faulty
  • jaykes Dec 15, 2013
    ok it was just the little bit of magnet that sits in the lid. that falls out and the waher doesnt know when the lid os open or closed. look on your lid and you will see a small hole on the LHS. that's where it should be. hope this helped someone :)
    New Friend:
Mine was filling, not agitating, draining, then rinsing with no spin. I changed the capacitor, not the prob. Fuse wasn't blown, tested switches in circuit board, suction thing was working. Advised by a professional that I needed a new circuit board: $260. By chance spoke to a feller who said to take the back off and locate the black casing running down the RHS to LHS. Undo the casing (make sure power is OFF). The blue wire that powers the motor has a habit if breaking, which is why mine had stopped.
Posted on Feb 07, 2013
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
786 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
