Why does the monitor say input not support on my screen, and it keeps moving all around my screen. Please advise
  • 225 Answers
Your computer's videocard is set to resolution/refresh rate that your monitor does not support. Turn on the computer and keep pressing F8 until the windows boot menu appear on the screen. Use arrow keys to choose VGA mode. You will get bigger than usual icons on the screen. Use Display properties from Control Panel to set the proper resolution.
Posted on Aug 07, 2010
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
I turn on my hp pavillon all in one ms225 and sounds like its powering up fan is running but nothing on my screen please help
Hi
I have just joined Fixya because I have a similar issue with a samsung 740n monitor. From reading through the site here I would advise you in the first instance to shine a torch at the screen and see if you can see any of what you would normally expect to see on screen with the help of the bright light. Dont shine it directly at the screen but at an angle approximately 45 degrees and keep moving it around. If you do see images or desktop stuff etc behind the black of the glass it is apparently an indication of a failing inverrter and knowing that you can do a further search on here to get instructions for your particular monitor.
That is what I am about to do now as I have been following advice but need to know what to do next so it may be worth following my first question as I am hopeful that I will get help and you might be able to use the same info.
Oct 15, 2012 | Computers & Internet
My laptop got broke, i'm using a small flatscreen monitor plugged into the back. a screen says "ATTENTION INPUT NOT SUPPORTED" just keeps floating around the screen. i don't know how to fix it
Start in safe mode and change the resolution to 1024x768 and 60Hz refresh rate. Restart and reset the resolution at the native of your display and 60Hz refresh.
Oct 28, 2009 | Acer AL1916W 19" LCD Monitor
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
We have a flashing rounded rectangular box moving around on the screen which says input not supported. What does this mean? How do we fix it? this is happening on our Acer Monitor for our computer.
Right after you start up the computer, start pressing f8. You will then get into a setup, choose VGA mode. If this does not work, try lowering the refresh rate and changing the screen resolution.
Aug 03, 2009 | Acer AL1916W 19" LCD Monitor
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
RGBPC input showing invalid format after move
There is nothing wrong with the connection, your TV or computer. Just changw the resolution settings under the display properties. Start with the lowest setting 800X600 and move your way up. It will eventually appear.
Jun 08, 2008 | LG 42LP1D 42 in. LCD HDTV
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
"input not supported"
what you may need to do is find an accepted screen resolution, as your screen is 19" widescreen and your notebook will be set for a normal monitor display, so either try the auto button on the screen or look at the properties of your graphics card om the notebook to find supported screen resolutions for extended displays.
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
