Question about Maytag LAT3600A Top Load Washer
Model # MAV6458AWW water will not turn off and overflows.....even when the power is off the water still runs in....If the faucet is barely turned on it is ok sometimes.... Is the water valve bad?
  • Maytag Master
  • 43,501 Answers
Yes the water valve has dirt stuck under the seat and it will not shut off the water completely...
You got it... replace the valve...
heatman101
Posted on Aug 07, 2010
F9,E0 error I cleaned the pump filter and hoses found debris in both. When I run the machine on quick wash with no clothes it works fine. When I put clothes in and wash the error returns
Need model number
F09 -
Overflow Condition (Pressure Switch Closed Too Long) - Check to make sure drain hose is not plugged or kinked and unplug the unit and disconnect power. Check wire harness connections to pressure switch, drain pump, and Central Control Unit (CCU). Check for drain pump failure and clean it of any debris. Check the inlet valve and pressure switch for proper shut off and operation. Replace failed component. Note: If this error occurs, the door will remain locked and the drain pump will run constantly even if 'cancel' is selected. Turn off hot and cold water to faucets and unplug the unit before proceeding.
Mar 14, 2016 | Washing Machines
Tip
How to maintain a Water Heater
A water heater can last you many years if you take proper care of it. Every few months, you should check your water heater for leaks and flush it out to avoid buildup of sediment inside the tank.
Before draining and flushing your water heater, turn off the gas or electrical power and let the water cool down a little. Close the incoming water valve, and attach a hose to the drain valve to run the water into a large bucket, or to a drain or the outdoors.
Open the drain valve, and turn on one hot water faucet somewhere in the house to let in air. When all the water has drained from the water heater, turn the cold water valve on and off until the water from the drain runs clear. Then close the drain valve and the hot water faucet, open the cold water valve, and turn the water back on.
This is also a good time to test the temperature-pressure relief valve, which keeps pressure in the boiler from building up too much. Lift or lower its handle. Water should drain from the overflow pipe. If it does not, call in a repair professional as this could result in a potentially dangerous situation.
on Sep 03, 2010 | Heating & Cooling
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 23, 2013 | Water Heaters
Hi I keep getting an error message "F27" on my
F27 OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Aug 31, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Have a pegasus shower faucet an it knocs every time you turn the hot water on in any part of the hause
Sounds as if you have air in the pipes.
To solve this you will need a piece of hose that will fit over the ends of your hot and cold faucets in the kitchen (or other lowest faucets in the house) - fix it on tightly with hose clips and open both faucets fully. Wait 5 minutes or so before turning off hot water faucet first.
If that hasn't cleared it repeat the process but after 5 minutes turn on your shower faucet and see if it splutters as the air is forced out. You may have to do this with other faucets in the house too. Close each one off once the water runs evenly without air in it.
If that doesn't work you will need to drain your hot water system down completely. Turn off water supply at the hot water cylinder (or rising main if you have a tank-less system) and open all faucets until water stops flowing. Close each faucet about 2/3rds then turn on water supply again. Wait for each faucet to get a slow but steady flow. Going round each faucet in turn gradually open each on a little bit more until all are running fast and even and all the air has spurted out. Now go round each faucet in turn closing each one down a bit at a time until they are only dribbling a small amount. Turn all faucets off.
Feb 17, 2011 | Plumbing
I have an f27 error on my washing machine. Can you explain to me where the pressure switch is? I have the front, back, and top off of the machine.
Error code f27 is OVERFLOW CONDITION.----------
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.----------
Check:----------
----------- This should help.Thank you.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It has a f 09 code
Hi.If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition will occur. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing the unit in this case.
Possible Causes / Procedure
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
The culprit in this situation could be the inlet vale, drain pump or pressure switch. Check all points above to isolate the issue. If you require a service manual to guide you through the necessary inspections, I will need your entire model number to post it. Post the entire model number, asap. i will post the proper service manual after i receive your model number and brand.
F-09 - Overflow Condition
Aug 24, 2010 | Whirlpool Washing Machines
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
Check
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Turn on cold water faucet and line starts to rattle
My experiance is something is clogging at the seat valve of cold side. Shut off cold water supply,remove stem,slowy turn valve back on to flush out possiable foreign object[s]
Mar 16, 2009 | Delta 2555SS-216SS Victorian Two Handle...
Maytag LAT3600A Top Load Washer Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
