Question about Dell 5500 (MF342) Wireless Adapter
I cannot enable my bluetooth, i have downloaded the driver but it says at install "uses wifi switch to enable bluetooth" but that seems to do nothing, also i got the laptop secondhand today and i'm not even sure of the right procedure to take to enable bluetooth in the first place, (it came with no manual) also i have no sound ((XP SP2))
  • 10,421 Answers
How to activate bluetooth using wireless switch
Step 1 Find the wireless switch, located on the front of the E5400, to the left of the touchpad.
Step 2
Slide the wireless switch into the "On" position to enable wireless radio communication on the Latitude.
Related Reading: How to Turn on Wireless on a Dell Latitude Laptop
Step 3
Click "Start ' Control Panel ' System and Maintenance ' Device Manager." Double-click "Bluetooth Adapters."
Step 4
Right-click the Bluetooth driver and then select "Enable" from the context menu, if available.
Step 5
Navigate to the Dell Support website in a Web browser if the Bluetooth Adapters category is not listed in Device Manager.
Step 6
Click "Start Here," then "Drivers Home." Click "Choose From a List of All Dell Products," then "Continue."
Step 7
Click "Laptops," "Latitude," then "Latitude E5400." Choose your operating system from the associated drop-down menu.
Step 8
Expand "Network." Click "Download File" next to the Bluetooth driver, then "Download Now."
Step 9
Launch the EXE file when the download completes. Follow the on-screen instructions to install the Bluetooth drivers to the computer.
Step 10
Restart the Latitude following setup to begin using Bluetooth on the E5400.
Jun 16, 2014 | Dell Latitude E5500 Laptop
Bluetooth indicator is not lit despite I switch the wireless ON
Confirm the phone number where you would like Verizon to call you. We will call you momentarily to connect you to our automated system. You can also call us at 1 (800) VERIZON (1-800-204-4427).
Apr 13, 2017 | Dell Latitude D830 Notebook
L412 wireless not enabled how to set up the wifi I already install the drivers but i didn't get any wireless symbol?
To set up the wifi try to install Bluetooth on your operating system then always switch on the Bluetooth, wireless symbol will be enabled.
Nov 15, 2011 | Lenovo ThinkPad L412 Notebook PC
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
No bluetooth operation. No SW to launch/operate BT device. Driver seems to be instaled fine and in full operation.
ensure that your bluetooth device is turned on most of the time it is with the wifi switch try turning it off and back on.
even though the driver seems to be installed fine there can be some complications try to delete and reinstall the driver
try installing Bluesoliel as your bluetooth manager instead of windows
Aug 18, 2009 | Fujitsu LifeBook E7110 Notebook
My Dell Inspiron E1505's wireless switch is off.
This happened to me using a Dell Inspiron laptop. The wireless switch was disabled and the answer was supposed to use both the blue Fn and regular F2 function key to enable wireless connection. I tried Fn and F2 together and it did not work. I tried just F2 alone and it worked.
Jul 25, 2009 | Dell Inspiron E1505 Notebook
Bluetooth won't work on Advent 5431
This model is not bluetooth enabled but yoy can buy and install a blurtooth adapter (dongle)
Once the adapter is inserted to an available USB port the appropriate drivers are installed
You can now access the bluetooth device from the control panel and get connected to any bluetooth enabled device
Jan 13, 2009 | Computers & Internet
My acer aspire 5050's wifi doesnt work...
Please Check in device manager, is there any problem with the driver ?
if there is a problem with driver, try to download driver from www.acerpanam.com and install it.
if there isnot any problem, try to enable wireless from the switch (close to external audio port)
Apr 09, 2008 | Acer Aspire 5050-3242 Notebook
Bluetooth...Help
first try to check in the program files if you have bluetooth installed.
start >> programs >>bluetooth >> bluetooth settings
look for the menu were you can activate the bluetooth.
also you can try. looking in the system tray icons. you will see the blueetooth icon in color red when it is disabled...right click on the icon and choose enable bluetooth radio.
Oct 29, 2007 | IBM ThinkPad R52 Notebook
Dell 5500 (MF342) Wireless Adapter Logo
209 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
