Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Power problem I recently moved my FreeAgent drive to another computer. I connected both the power and USB connections in, with the power turned on, yet the drive still seems to have no power. I've tried several things including replacing the fuse, switching USB ports, restarting the computer (the detection software is installed on it) yet nothing happens. How do I fix it?
  • 4 more comments
  • DavidLF May 10, 2008
    I'm having exactly the same problem - the wpower supply seems to have died to the external drive!!!!!!
  • Anonymous Jun 26, 2008
    I am unable to get power to my seagate, this is a fairly new device, less than 6 months old. I purchased it so that I would not loose data from my laptop, and now I am unable to retreive the information. This is drastic, I have a lot of school work on this device which I am unable to retreive now. Anyone have the same issue?
  • johnson27 Jun 29, 2008
    I have tried everything possible to power up my seagate. Is there anything else I can do? Is it possible to pull out the hard drive and buy another case for it to run in?
  • BludBubbles Jul 18, 2008
    I have the same problem but have made some but very little progress. I am in the process of having a new Power Supply being shipped to me. Unsure if this will help because I think the current one I have is working correctly because the drive will still get warm when plugged in. I know it's not the USB cabel because I used the same cable on an MP3 player and everything was detected correctly. The power will not come on. But on a few occasions of messing with it, I got the drive's Amber Light to come on, but the light that pulsates just stayed lit brighter than the rest of the Amber Light Band. I could feel no action, moving parts on the inside, and computer does not detect. I have tried on a Desktop and Laptop both running Windows Vista and 2.0 USB. Waiting for the power supply and hope I am able to get it working. 700 GBs of info gone and I was told data recovery would be anywhere between 850 to 2400 dollars. Any help would be much appreciated and if I figure anything out I will post my findings. Thanks.
  • subodh r Aug 17, 2008
    hi i have a segate free agent 500 gb eSata\USB drive . the drive was workign perfectly .. but i had it disconnected fo some days . Now when i try to connect it , It simply refuses to boot . I tried changing the power point. the amber light does not glow. . what can be the issue ?. Please help i had got this drive to back up my 4 years work ineed to get it working anyhow .. please help .. please help.
  • Anonymous Sep 01, 2008
    I have the same problem on first use. Moved some files to the drive, rebooted the computer, and then nothing. The drive has attempted to come back to life once and I could see my files. I thought it was working again, but no.
Try using a different power supply/ac adapter. My Seagate Free Agent Pro didn't power up, but when I switched cords, it worked. I've gone through several drives, and Free Agent's are by far the most reliable.
Posted on Jul 31, 2008
I have purchaed the Seagate Free agent pro external hard drive one month before. I moved around 200 gb of my very important data to this drive. Now it is not working. Initially there was no drive shows in my laptop. Then the light is not showing in the External drive.
I called the seagate office. They are going to send the cables.
Please do not buy this ********* drive.
Posted on Aug 16, 2008
So does any body have a solution to these problems or do we just get our money back?
Posted on Jun 27, 2008
Just reading this forum I think I have bought a total POS. Damn! wich i would have read this first. This boat anchor has all of my backup on it, is only a month old and is now junk. What is this the 3rd world's way of collecting all of our data when we return them?
Posted on May 29, 2008
Power to Seagate FreeAgent Drive is Unstable
You might be able to swap the drive to the other portable drive. Or, if you have a slot in your PC, put it in there. If it runs normally, the PS is shot (wouldn't be the first). Either get a new case with PS, or keep it in the PC. You can power it down when you're not using it.
It's also possible the drive is bad. Find the HDD diagnostic tool in your OS and check it out.
Apr 08, 2017 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
How can I power up my seagate 7200.11 500gb external h/drive to my pc
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Oct 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent Go not recognized as an identifable USB device.
I plugged mine's directly through the back of my computer instead of the hub in the front and it's working fine.
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
The light on my Seagate freeagent go flashes quickly when it is connected to my computer, indicating an error. What should i do?
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Jul 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I'm sorry my enlish verry littl. Mi HDD Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive No runing. I chenj cabl
Hi. Is the power light on the drive on? Is it flashing (this indicates an error)? If it is check the usb port you are using. You cannot use a usb hub, a usb port on a monitor or any other port that is not directly connected to the computers power supply. If you are using a dock make sure that both of the plugs are connected to powered usb ports. I could not get this drive to run until I plugged it into the right port. Use only the short cable that comes with the drive or the dock that is made to use with the drive. I hope this suggestion helps.
Jan 15, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Corrupt External Hard drive
I have a 250 g ext.drive. I moved all my pictures from my pc to it and now the hard drive will not open. It is nearly full. It acts like there are no files on it. What should I do, unplug it?, restart the pc, plug it into another usb port on the pc.....help????...all of my pictures are gone!!!!!..........RB
Mar 23, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
USP-porti doesn't find the external hard disk - occasionally
If it has been working and now does not not. If the system is ME or NTFS[XP /2000/VISTA] If the port check shows nothing untoward Then you must look to the the disc or its connection or power supply. So -if you can check out the power supply Is it self powered[internally of via a 'power brick'] or does it rely on USB power from the computer? If the latter- disable/unplug some other other USB devices. If it 'works on its own power' check that it is indeed running. Change the USB cable for another. Comeback if still in trouble
Sep 09, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
307 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
