Question about Coffee Makers & Espresso Machines
I need the rubber gasket that goes over the puncturer on my Kuerig coffe maker
I have the Keurig B-40. It is about 3 years old. Lost the Rubber Grommet. Went to Lowes and picked up a 7/16 OD x 3/16 ID Rubber Grommet for $1.27 ~ Problem Solved.
Posted on Nov 11, 2010
  • mommybreezy Apr 14, 2011
    Thanks for the tip. I haven't tried it yet. But, this appears to be the only real solution I have found for this problem.
There is no hole in the bottom of the kuerig k-cup. Is there possibly a part missing?
The Keurig will puncture the K-cup when it is inserted before brewing. If it is not being punctured, the brewer is damaged,
Oct 08, 2014 | Coffee Makers & Espresso Machines
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Oct 07, 2013 | Coffee Makers & Espresso Machines
I have a Keurig B60 coffe maker and when i make coffee it seems to leak out the sides such that that coffee is not directly coming out the bottom holes. I have cleaned the bottome holes to ensure...
Hi, Yes, you are missing the gasket around the top needle...
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Sep 20, 2011 | Keurig B70 Coffee Maker
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
May 06, 2011 | Vacuums
Gasket - coffee grounds in coffee
hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
Apr 03, 2010 | Keurig B70 Coffee Maker
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Feb 06, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Incanto deluxe is leaking
sometimes the spout in the door is kinda clogged. Take this out ) need phillips head) and clean it . Make sure to turn the knob on it to left and right while cleaning.
There is no gasket but the little plastic pipe goes in there.
Should help.
Check this for parts SAECO
Jun 01, 2008 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
641 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
