Question about GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher
Model # GLDL560n10ss - Appears to fill and cycle but does not drain??
Washing machine won't wash after filling
have a technician inspect but it appears that you have a faulty control panel
May 05, 2015 | Washing Machines
Washer tries to fill, but water goes straight out the drain.
Either washer drain hose is too far down drain pipe, or there is a airtight seal where drain hose and house drain meet. Either would cause siphon effect.
Sep 06, 2017 | Washing Machines
Wont drain, no pump
Hi it sounds like a blocked pump needs cleaning out
Feb 17, 2010 | Dishwashers
Fills up to start cycle, but then begins to drain.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 03, 2009 | Washing Machines
Whirlpool GU980 gold fills runs for 5 seconds then drains
Appears that the controller has gone ballistic and is now doing its own thing. That part may need replacement. Search Over 2 1 Million Appliance Parts
Sep 05, 2017 | Whirlpool Dishwashers
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Washer sometimes drains durring the rince cycle
Ave, sounds like you have a siphoning problem. Check your drain hose and make sure there is a gap to break the siphon. Sometimes I find the drain hose shoved too far down the drain causing this problem. Another thing you might want to check is the drain itself. Is the drain water backing up causing the drain hose to be submerged after the initial drain? Catriver..post back.
Nov 18, 2006 | Roper RAS8445KQ Top Load Washer
GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher Logo
103 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
