I get no sound from zone 2 on my Onkyo SR650(B) I have analog sound hooked up from a DVD/CD player and I have also tried the FM tuner with no results. I have verifed the speakers with a old unit I have so it is not the speakers
  • 2 more comments
  • steve040 Apr 27, 2008
    The manual is available online I mistyped it is a Onkyo SR605(b)
    Not from the Onkyo. from the old unit they are crystal clear.
    Will that reset everything?
    I am hooked up correctly and I have activated zone 2
    Genius:
  • 1,447 Answers
Heres how you should connect it
Posted on Apr 27, 2008
  • 1 more comment
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 27, 2008
    here check the manual:
    http://www.eu.onkyo.com/dl/814833/HTR640...
    this is the closest i can get for you
    How about the output setting on the dvd itself did you try changing it as well?
    and set audio connection as small "a" since you are using analog and match it on the DVD audio setting
    Genius:
  • 3,422 Answers
Try reseting it.Press "Video 1" and "CD" for a second, and if that doesn't work, look in your manual for the correct combination.
I'll let you know if there is a manual available for your model.
Goodluck..
  • 1 more comment
  • Priya darshan Apr 27, 2008
    ok,Please CLICK HERE to download the manual
    Yes,it will reset everything.
    I have got the manual from onkyo's website CLICK HERE to download
    If my solution helped you in fixing your problem.Then please don't forget to rate the solution no.2 as fixya
    ok,Now my solution no. is 1.Please try a reset if this fixes your problem then rate my solution as fixed.the solution no. keeps changing so please see the name of the expert and then rate.
    President:
  • 1,944 Answers
Do you hear anything from the speakers? Even static?
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Zone 2 speakers only work with the tuner - no sound comes out when switched to DVD, Cable/SAT, ect. All of my other devices (DVD player, Satellite Receiver, ect.) run through the receiver. How do I get...
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Jun 10, 2009 | Onkyo TX-SR605 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Zone 2 sound
actually, the zone 2 for onkyo receivers are built to only react to analog sources so if a device is hooked up using digital cables, the zone 2 will not pick it up. if you want to listen to a source in zone 2, you would have to hook up a red and white RCA cable.
Nov 08, 2008 | Onkyo TX-SR605 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Zone 2 Audio
help! screwed up z2 was working until i messed with it. do not know how to reactivate or even reset.
Apr 27, 2008 | Onkyo TX-SR605 Receiver
Zone 2 Can't Handle a Digital Input ? ! ? ! ?
it is very frustrating... I just have discovered today. I can't solve this because my Itunes mac is only digital audio output, I can share its sound to Zone 2..
Apr 16, 2008 | Audio Players & Recorders
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
Mar 25, 2007 | Onkyo TX-SR700 Receiver
66 people viewed this question
 Grubhead
Grubhead
