Question about Toshiba TDP-T45U DLP Projector
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace the "tube". What? a TUBE? In a solid-state device? Did he mean "lamp"? The lamp is fine, but for the thin lines. Can't be lamp...
  • webboid2 Aug 07, 2010
    setup is disabled -- get [X] in upper left corner of screen when setup button pressed...?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Posted on Aug 10, 2010
How do I get rid of this one vertical white line on my toshiba TDP-S8
take the cover off, disconnect the the connection on the rear of the lens assy from the main board, clean with an approved electronics cleaner and then reconnect. Sometimes this fixes the problem. If it doesn't, then the DMD on the rear of the lens assy is bad or the main board is bad. Hard to tell without a test fixture.
May 20, 2010 | Toshiba TDP-MT800 Multimedia Projector
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
you can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Feb 05, 2010 | Toshiba TDP-T45U DLP Projector
I have a toshiba tdp-t45 and a Dell D600 how do I get the image from the computer to display from the projector?
Connect the toshiba tdp-t45 to the back of the D600 and then hold down FN and tap F8. This will transfer the video to the tdp-t45. If this does not work for the first time try the Fn and F8 keys 2 - 3 times.
Rate if useful.
Aug 11, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
TDP-S8 only run for 20 sec.
Possible filter problem or sensor related to over heat. Might also be a bad bulb or worn out bulb.
Leaning more towards bulb replacement.
Dec 08, 2008 | Toshiba TDP-S8 Multimedia Projector
Two or more black bands appear
Try resetting all parameters to factory settings. Do it once and then set your personal settings. Then, reset to factory defaults again.
Jan 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T45U DLP Projector Logo
263 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
