Question about Sony VAIO PCV-W600G PC Desktop
I cannot load gigpocked software drivers and tv card drivers from the disk, is there anywhere i can download all i need to work the tv side of this computer. thank you...
Have the same problem. After chatting with the online help, they informed me that I need to purchase the original discs to get this software. When I try to do that it says that they are no longer available and neither are the replacements. I emailed them for an answer to the problem. I saw on a forum that there are companies that have the discs, but so far I havent found them. BUMMER!
Posted on Jul 15, 2008
I can't get to the Motion Eye web cam on my Sony Vaio. I just got it , didn't remove any hardware
It is possible the Software is either dormant, it means it needs activating, or it was not installed when windows or sony Vaio was downloaded.
Go to Sony website and downdoad for free
Aug 05, 2010 | Sony VAIO PCV-W600G PC Desktop
Vaio pcv w600g needs a multimedia video controller update and i cant find the driver. Thanks
Have you tried this website, they have all your drivers in there
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVW600G
if it works for you don't forget to rate me
thx
Apr 29, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
No sound at all
Do you have a driver installed? Go to device manager to check it. If not, go to Sony help and support and there you can download the audio driver you need
Nov 26, 2009 | Sony VAIO PCV-W600G PC Desktop
VGC LS25E, when booted, the screen is completely white, although the hard disk indicator blinks and you can heard the hard disk working.
If you're lucky, the cable between the laptop's video card and display has come loose at one end. This is a hardware issue and unless you are quite competent with moderately difficult repairs (laptops are unpleasantly intricate to work on), you are most likely going to need a qualified tech to repair it.
Jun 06, 2009 | Sony VAIO PCV-W600G PC Desktop
I spilled water on my Sony Vaio one piece PCV-w600g keyboard
You can use the "USB" connection on your lap top to use just about any keyboard.
Replacement Parts: http://esupport.sony.com/US/perl/model-accessories.pl?mdl=PCVW600G
Feb 20, 2009 | Sony VAIO PCV-W600G PC Desktop
Semicolon problem
Have you tried restoring the system to original manufacturer's default from the restore CD? also before you do that try to get another keyboard and see if it happens with a different keyboard, it might be the key that is stuck or really sensative.
if you don't have the system restore disk, you may find it at the Sony.com technical support website for this specific workstation.
Feb 09, 2009 | Sony VAIO PCV-W600G PC Desktop
Freeeeeeeze problem
Sounds like you may have a bad power supply. It's a cheap fix, abd always a good upgrade. I recommend at least a 400 watt power supply.
Mar 19, 2008 | Sony VAIO PCV-W600G PC Desktop
Sony vaio tv tuner card and tuner card driver problem
You'll need to go to the sony website and download the MPEG encoder Driver. http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVV200G&upd_id=1415&os_id=7.
You might want to download the latest update drivers from this site also.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVV200G&LOC=3
Feb 14, 2008 | Sony VAIO PCV-V200G PC Desktop
VAIO PCV-W600G DESKTOP
Try unplugging components one by one (disk drive power, CD power, video cards, etc) with the system unplugged and see if the fan speeds up when you restart it. Note than when you remove certain cards, video for example, you may get beep codes.
Everything in a slot on your PC shares a common power bus so any card installed may be pulling too much load on your power supply. Pull em one by one re-starting between each one.
If this doesn't locate the fault, check the power plugs to your disk/cd drives and ensure that you are getting 12VDC between the yellow and black wires and 5VDC between the red and black wires.  If you are not, and you have already pulled all cards/drives, you have either a defective power supply or your motherboard is drawing too much current.  In the last case, pull your memory cards one by one and re-start between each pull.
YOu will get memory size errors if you let the boot procedure go too far but all you want is for the fan to go.
You  can accurately pinpoint POST errors with a POST diagnostics board available at most PC shops. It comes with a code manual.
Oct 15, 2007 | Sony VAIO PCV-W600G PC Desktop
Sony VAIO PCV-W600G PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
