Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Bought model 635t filter pump and it doesnt seem to hook up to my 15 x 36 intex pool
  • Jeff Pepper Jun 03, 2012
    Since there really is no warrantee, the answer is simple. Blow up the top to make sure it has no holes. If it does, return it. If it does not, then what you want to do is use a pointed tip soldering iron and literally cut out the two black nipples. You want to cut around the black cirle but for best results, just outside the black but not too far. Essentially you are cutting out the black nipple. The soldering iron seals the rubber and you should have a tight fit. Make sure you do not puncture anything with the soldering iron so be careful and take it slow. In ten minutes, your problem will be solved..
  • 52 Answers
Try using Hard pvc plumbing as opposed to hoses
The Pool Tech
Posted on Aug 08, 2010
  • Scott Sagrera Aug 08, 2012
    What a joke this guy is.
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
try to get the vacuum that works with the garden hose they work ok for the small pools
How much horsepower does my intex Crystal Clear Model 635T filter pump have? I'm looking at a hth vacuum that requires at least 1/2 horse power. thanks
If the unit does not have the horsepower rating, but has the AMP rating, try this formula found in Answers.com
"Amps are a factor in calculating power, and so can be used to determine horsepower, but only when other factors are present.
Given other factors, you can find the horsepower. The easiest way is to determine watts by multiplying amps X volts. Next multiply watts by .00134 and you have horsepower.
If: amps (A)= 20 and volts (V)=120 then
A X V =2400 watts (W)
2400 watts X .00134 = 3.216 horsepower"
Hope this helps you???
Aug 14, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Water leaks out the top of the filter housing. I ordered "o" ring 10266 (filter housing "o" ring) and it is too larger. Where can I find a schematic with part numbers.
Here's the diagram for the 635T.. The o-ring for the top valve should be part number 10264- #3...small o-ring. The housing cover is the bigger o-ring 10325 #5.. Hope this helps you...
Aug 11, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Jun 28, 2009 | Intex 4000 GPH Filter Pump
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
347 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
