Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
I have the 6310 pullout faucet in bone and the finish paint has started to come off where it meets the corian counter i have had the faucet for three years can you help or have advice
I had the same problem and contacted American Standard. They had me email them pictures of the problem and sent me a new faucet free of charge.
Posted on Oct 19, 2010
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
How to tighten faucett ? It has loosened from counter.
under the counter inside the cabinet, you will see a set screw or nut that needs to be tighten up from the under side.
Apr 26, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
It seems like the rings expanded or something. No
I got old pullout srayer out bought a universal one and it will not go through. What part number do I need. Can I buy that piece.
Dec 21, 2009 | American Standard Kitchen Faucet 6310 020...
We just had it installed, Kitchen counter top, moss Green in color -Corian moving coffee pots with rubber feet leaves scuff marks , plates ceramic or china leaves scuff marks also , and they can not be...
Countertops
Cleaning All Finishes
Most dirt & residue
Use soapy water, ammonia based cleaner (not window cleaner), rinse and wipe completely dry. Commercially available solid surface cleaners, such as Clean EnCounters® will also work well.
Preventing hard water marks
Rinse and wipe completely dry after cleaning; clean up spills before they dry.
Removing hard water marks
Use a cleaner formulated for removing hard water marks such as CLR or Lime-A-Way.
Difficult residue
Spray residue with Deep Cleaner for DuPont Corian® from Stone Care International. Follow instructions on the bottle. Wash area with soapy water, rinse and wipe completely dry. If residue persists, follow steps below for removing dulling film.
Disinfecting
Occasionally, wipe surface with diluted household bleach (1 part water/1 part bleach). Rinse top thoroughly with water and wipe completely dry.
Preventing Heat Damage
While Corian® is heat resistant, as with all countertop materials, it is important to minimize direct heat exposure to protect your surface and investment.
DO NOT PLACE HOT POTS, PANS, ETC. DIRECTLY ON THE COUNTERTOP SURFACE.
Always use heat trivets or hot pads when placing hot objects on any surface. Always use a trivet under portable heat generating appliances such as a toaster oven. Allow cookware to cool before placing it into a Corian® sink. Preventing Other Damage
In most cases Corian® can be repaired if damaged. Be sure to follow these guidelines to help you prevent any permanent damage to your Corian®.
  • Avoid getting strong chemicals, such as paint removers, oven cleaners, etc., on your Corian® countertop. If a spill does occur, promptly flush the surface with water to fully rinse off the chemical.
  • Do not cut directly on Corian® countertops. Use a cutting board.
  • Boiling water alone will not damage your Corian® sink, however it is a recommended practice to run cold water from the faucet while pouring boiling water into the sink.
Removing fine scratches or a blotchy appearance
You may notice that the surface of your countertop begins to look blotchy. Typically, this is caused by leaving hard water to dry on the surface which will leave a film of minerals. To remove this film:
  • Pour some mild abrasive liquid cleanser, such as Soft Scrub®, on a damp sponge or cloth and rub over area using small circular motions, from the front to the back, then side to side, overlapping the circles until the entire area has been cleaned.
  • Thoroughly rinse the top with clean water and WIPE SURFACE COMPLETELY DRY.
  • Check to see if blotchiness is gone. If not, repeat procedure applying more pressure on the sponge or rag.
  • Continue over all affected areas until all film is removed.
Your new Corian® installation entitles you to certain quality assurance standards as provided in this Residential Limited Warranty. To obtain information and service under this warranty, contact the source from whom you purchased your DuPont™ Corian® installation or DuPont at www.Corian.com or call 1-800-426-7426.ifrcor_corianwarranty_10
Dec 21, 2009 | American Standard 7236.LBW.950 Glacier...
Faucet leaks at base of spray handle when water is turned on. How can I fix this leak?
most of the the pullout sprayers need a rubber washer were it meets the hose chek for cracks and replace.
Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
I have an american standard pullout disc faucet which is leaking. I replaced the disk. Now it is leaking more than befoe from the base. What should I do? Is it the o seal at the bottom? chuck
Chuck,
Definitely change the O ring, and ensure the disc is installed properly, as well as ensure there is no debris on the disc. It sounds like the O ring was torn during the first procedure. Good Luck.
Steve
Oct 11, 2009 | American Standard Kitchen Faucet 6310 020...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
Need to install faucet
there need to be 3 coming off tap hot cold and infeed to pull out counter wieght about half way on pull out use plumbing tape thank you for useing fixya
Feb 22, 2009 | Price Pfister 18 Series Polished Chrome...
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
210 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
