Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
The original hard drive on my Dell Dimension 5150 has fried, and I bought a new one and installed windows on it again. Is it possible for me to retrieve the files on the other hard drive with just the single signal wire or whatever it is?
    Scholar:
  • 151 Answers
If your drive is fried, then file recovery may not be possible.
If you are using a SATA hard drive that uses the thin cable with a small connection at the ends, you will also need to connect a power cable as well.
you should be able to hook up your old hard drive into your PC if you have a second SATA cable and a spare SATA power connection.
Splitters are availible at most PC shops, and should not cost very much.
Once again, if your drive is completely fried or burnt out, file recovery may not be possible.
Posted on Aug 09, 2010
Max hard drive that can be fitted to a dell dimension 5150 thanks tom
Sir your Dell dimension 5150 can be expanded with maximum 250 GB of hard drive .
Thanks.
Have great day.
Oct 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 won't load drivers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Jul 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Dell Dimension 5150. I was working on a project when the computer froze up. I had no choice but to turn off by the power button. Now it will not boot. Says there is no bootable device. I tried...
If you have a bootable xp disk handy set up the computer to boot from dvd-rom or cd-rom, put the disk in the drive and let it start setting up windows, Once on a blue page where you have a few options choose "R" for recovery console, it opens up a command prompt page. When in the command prompt page type: chkdsk c:/f and press enter, let it run. When finished restart hopfully its all back to working order.
<Change drive letter to the drive you use if it is other than c:>
You could also get another hard drive set as master and set the other as slave, load a copy of windows onto the c: drive and boot it up, all your files should now be on drive d: your original boot drive.
Let me know how you get on. thanks
Jan 19, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller driver needed
You can download and install the required drivers from Dell's official website. Click on the link below:
Drivers & Downloads for Dimension 5150
On this page there are four files, download them all and install them. You should be able to use your network card after successful installation.
Note: If the above link is not working, go to www.dell.com. On the top right corner of the Dell's website click on 'Support'. A new page will open from where you choose Drivers and Download option. Next step is to choose your laptop model.
Oct 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
Jan 31, 2009 | Dell Dimension E520 PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Dimension 5150 won't boot
check your hard drive I think press f2 or f12 for hard drive test or reboot. If it is the hard drive and its out of warranty check w/new egg just bought one for my 510 dont forget to check hrd drive connection type ata or sata good luck
Nov 09, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
79 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
