Question about Dell 922 All-In-One InkJet Printer
Trying to install a circa 2004 Dell 922 printer on to my daughter's Toshiba laptop with Vista OS. No go for any of the fixes from other forums or Dell's tech. Any sure fix? Is it worth the drama?
  • 1 more comment
  • khenry51 Aug 08, 2010
    do I save the drivers to the desktop like other suggested or to C drive or what?
  • khenry51 Aug 09, 2010
    Uninstallind and re-installing doesn't work. Installed Lexmark drivers...doesn't work. I have the printer showing as installed, set as default printer but get the "the printer can not communicate with the computer" response and that's as far as ot goes.
  • khenry51 Aug 11, 2010
    Took a little doing but I finally got this suggestion to work so thanks I hope this sticks.
  • 3,153 Answers
I am honestly surprised you still have a 2004 printer running so I am quietly impressed with its quality.
Ok Dell tend to use LEXMARK so maybe if you cross refference to the correct lexmark model you could try drivers from there.
However there is a difference betwen Vista 32bit and 64 bit with drivers so make sure you get the correct ones
It is based on the Lexmark X5270.
With a service record like that for an AiO printer I would put a little more effort into it for sure
The drivers from Lexmark are available here
Posted on Aug 07, 2010
  • 1 more comment
  • Project NOMAD
    Project NOMAD Aug 09, 2010
    OK it sounds af if the drivers are fine.
    I am going to suggest you change how it is connected to the computer
    First off remove as many USB devicers as you can that you will not need for this little test.
    Now connect the USB lead from the printer DIRECTLY to the computer and NOT via any hub etc.
    Try that and se if you get any changes.
    If not then SWAP the lead for anotherone preferably shorter and see if that helps.
    Also try it in different USB ports too (may involve a re-boot)
    Let me know how you go on as I have seen first hand in this game that not all USB leads are created equal even though they should be ! In fact USB problems are one of my number one issues and often fixed very quickly at no cost most of the time
    I have uninstalled the Lexmark drivers. So this time, do I save them to my desktop? Then you said "Now connect the USB lead from the printer DIRECTLY to the computer and NOT via any hub etc". Sory but this needs to be at first grade level. What does that mean?
  • Project NOMAD
    Right
    The power to your printer needs to be plugged in to the wall outlet and switched ON so that your printer is powered up.
    Now follow the cable that goes to the computer and make sure it goes DIRECTLY to the computer and not via anything else. If it goes to a small device that allows you to plug lots of USB things in then disconnect it from there and plug it DIRECTLY into the computer even if you hav to disconnect somthing else to do that (apart from keyboard & mouse)
    Also if you have anything else that is connecting to the USB ports on your computer apart from a keyboard and mouse then DISCONNECT those too for the moment
    Genius:
  • 1,035 Answers
Hi. I've checked at Dell's website and the only available driver is forn Windows XP and Windows 2000. Probably the one that your are trying to isntall is for Windows Xp. I ahve provided you a link where to download Vista driver. Available format is 32bit and 64bit version of Vista. Please click here.
Have a good one!
Posted on Aug 09, 2010
  • 2,973 Answers
Disconnect device, uninstall its drivers, reboot, reinstall drivers, reboot, reconnect device and allow windows to detect the device, load its drivers and tell you that new HW is installed and ready for use.
Posted on Aug 08, 2010
Dell 922 aio wontcommunicate with windows vista
********If u have installed the drivers from the old printer cd (used for windows xp ) ..on to ur vista os ,,,then we have some real problem and could take time but can be fixed *****
If u have not installed any of printer drivers …then u should be able to print (cannot scan ) , jus as connect the usb cable to the pc and ur firewall or comp settings may be blocking the communication . *********replay to me and I will help further********
Oct 26, 2009 | Dell 922 All-In-One InkJet Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
I assume the old computer was not Vista
This site has the vista 32bit driver
for Dell 922 AIO http://www.techspot.com/drivers/driver/file/information/8761/
Nov 21, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 AIO NT 4.0 driver is blocked
Download the printer driver from dell web site and try to reinstall. Before reinstall the printer driver you need to uninstall the previous printer driver from control panel->program feature->dell printer
Dell 922 Photo All-in-One
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Regards
http://ithelpdesksupport.blogspot.com
Aug 11, 2009 | Dell 922 All-In-One InkJet Printer
My dell 922 aio was functioning properly when I had windows XP, now that I have Vista, only the printer portion will work and not the scanner or fax. Do I need updated drivers?
Yes,
Here is the web page to download:
Dell 922 Vista
I would Save the files to your computer and install them from there and not Run them from the download page.
Thanks for using Fixya.
NOTE: Uninstall the previous software before installing the new driver.
Jul 08, 2009 | Dell 922 All-In-One InkJet Printer
Printer (922) won't install on new laptop
If your laptop is running Vista and your old desktop was running XP and the disk you got with your printer had drivers that worked with XP and Vista is not listed on them, it would be a case of incompatibility. You would need to go to the Dell website to download updated drivers for Vista if they are not of the standard Vista driver package. (The driver model changed between XP and Vista making XP drivers incompatible with Vista.)
May 27, 2009 | Dell 922 All-In-One InkJet Printer
Dell Photo all in one inkjet printer 922
i have a hp vista laotop and now i cannot scan
Oct 22, 2008 | Dell 922 All-In-One InkJet Printer
Printer doesnt print with Vista (Dell inspiron 1720 laptop)
install the right driver for the right OS platform pls download from website the driver
Sep 02, 2008 | Dell 922 All-In-One InkJet Printer
Dell has a new program for Vista printers. It involves uninstalling the previous drivers and then installed that new drivers. It is located at this link:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A922&hidos=WW1&hidlang=en
Jun 29, 2008 | Dell 922 All-In-One InkJet Printer
Use with vista and XP
yes you need to download windows vista printer driver for dell 922 on the laptop for your desktop leave it as it is.
Get on web and search printer drivers for dell 922 windows vista install on laptop and youre done
Nov 29, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
