Question about Dryers
Fuse was replaced and ran for one cycle and now won't turn on.
  • Dryers Master
  • 2,699 Answers
What fuse the thermal fuse?if so did you clean out the dryer?the fuse usually pops because the dryer is runnung to hot,you need to clean out the duct that the lint filter slides into,blow out and vac the motor and the cabinet area where the motor is and clean out the vent line and the outside vent,if the vent lint is long use a leaf blower to clean it out.all a dryer does is move air,if the air can't move your gonna have problems,if it's gas you should do this once a year,electric every two years
Posted on Aug 07, 2010
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
see this causes and fix it. God bless you
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
2000 nissan maxima won't fire when trying to start. it turns over but won't fire. it started once and ran but won't start again
sounds like it might be flooded. Try and remove the fuel pump fuse from the fuse block that is just in front of your left knee. While it is out crank the car and see if it wants to start and hold down the gas pedal all the way and then relase it and back and forth and once you get it to run have the fuse ready in your hand and in front of the spot to install it. and then keep the rpm's up with the gas pedal until the smoke clears out behind the car.
Jul 02, 2011 | 2000 Nissan Maxima
Dryer jus blows cold air on heat cycle and i replaced thermal fuse
either you have an open limit or your element is bad . thermal fuse if bad won"t even let dryer turn on
Jan 25, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Hi can you help me my car batter was replaced now i dont have raidiow can you help plz its a rover16
eather there is a wire missing from the battery look around some one might have ran this stright to the battery the way you knoe this is if you turned off the car and your radio worked then it was stright wired or check the fuse
Dec 08, 2008 | Car Audio & Video
Dryers Logo
Top Dryers Experts
Marvin
Marvin
