Question about Sharp XR10XL DLP Projector
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
  • 89 Answers
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
Posted on Aug 10, 2010
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR 10X lamp replacement issues
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Oct 01, 2008 | Sharp XR-10X Multimedia Projector
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Sharp XR10XL DLP Projector Logo
428 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
