Question about Arris SURFboard® SB5101 Cable Modem
I just moved and trying to hook up my laptop to modem and wireless router but can't get the modem to work without the wireless.
    Scholar:
  • 104 Answers
When you move somewhere else you have to configure the laptop for that region's phone line.Go into control panel and into internet connections.Go to" set up an internet connection"This will take you through the set up procedure.THE IMPORTANT THING IT WILL ASK YOU IS YOUR REGIONAL CALLING CODEI.E. 0208 IS THE OUTER LONDON CODE.
Posted on Aug 07, 2010
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
Cant get wireless internet...however i can when mx6445 is hook directly to modem
connect directly to your wireless router, hook the modem to the router WAN port. From the computer type http:\\192.168.1.1 and log into the router. First make sure you can get Internet on the laptop through the wired connection. Then setup wireless without encryption or WEP and see if you can attach to the device unsecured.If both of these work, set WEP up and make sure you use the key and not the passphrase to authenticate.
The key looks something like AAB4562E...
Mar 26, 2010 | Gateway MX6445 Notebook
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
How do hook up a wireless laptop to a router and
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Feb 04, 2010 | Belkin Computers & Internet
My laptop connects to the router but the internet doesn't always work. The connection is perfect yet most of the time it won't go anywhere. Sometimes if I move the laptop around a few inches it'll work for...
Greetings,
If the laptop is hooked up by ethernet cable and the problem happens when you move the laptop, you either have a bad ethernet cable or a bad ethernet port in your laptop.
Probably the best thing to do in your situation is since you have a wireless router, enable wireless on your laptop and use that instead and work wirelessly.
Let me know if you need help setting it up.
Aug 31, 2009 | Belkin F5D9231-4 Router
Can you hook up the router without hooking to a tower
Yes the Router can be hooked to a high speed modem like DSL or Cable, that high speed connection would go from the modem to the "internet" port of the router. Now the router would need to be configured if you need wireless, and then a temporary connection to a tower or laptop would be needed.
Aug 10, 2009 | Linksys Wireless-G Broadband Router
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Trying to get router to work
that would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Oct 22, 2008 | Computers & Internet
Arris SURFboard® SB5101 Cable Modem Logo
101 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
