Question about Brother MFC 420CN All-In-One InkJet Printer
My PC tell me that the printer is ready to print, yet nothing shows up or prints. I even replaced the ink.
    Scholar:
  • 50 Answers
Well it depends if it is a wireless printer, the firewall, whether in the internet security suite if you have one..
If not then it would normally be something as far as the drivers for the printer are just not working correctly and if so follow these steps..
Go to Control Panel then to Programs and features/add and remove programs..
then look for the associated printer.. uninstall the printer and all associated for cleaner re-install
then reboot and when it comes back on just have the printer unplugged and reinsert the CD and run the setup again, and when it prompt for the USb to be plugged in or wireless..
select which applies and continue setup after finishing the issue should be resolved...
P.S. if wireless and u tried disabling the internet security firewall and it still didnt then do above step as well and re-install... note the windows firewall does not necessarily block the printers from printing in the newer OS... usually a third party software... webroot, AVG... e.t.c.
Good luck give it a shot, got nothing to lose but printing to gain...
Posted on Aug 07, 2010
Hardware error 03130031-2f13 on IPF650
update your firmware version to 1.35
if your printer firmware is 1.32 and below. try this linkhttp://software.canon-europe.com/software/0027485.asp?model= follow the instruction included.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Canon Printer Support
Feb 27, 2014 | Canon imagePROGRAF iPF650 largeformat ...
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
My TX 100 will not print. I have replaced black cartridge thinking it would change things but no. The green button shows and the red one shows (the red one shouldn't) and when I press 'print' it...
Epson ink cartridges have memory chips. If you refill a cartridge it will still show as empty until the memory chip has been reset. The printer will not normally print if it thinks the ink is empty. This is to protect the printer as the ink is energized as it is used.
Refill ink sellers on line usually have the Chip Reset tool available to buy (SK168-II).
Apr 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printer won't print on my MacBook
had the exact same problem and was ready to trash printer.  Then I played around with the print settings.  Set picture size to postcard and magically it printed.  Try it
Nov 09, 2007 | Canon Selphy CP510 Thermal Photo Printer
Printer not printing
It sounds like it is out of ink. If you have replaced the ink cartridge recently, is it possible you forgot to remove the small piece of tape that is placed over the head to prevent ink leaks? That has to be removed before installation.
Aug 28, 2007 | HP DeskJet F380 All-In-One Printer
Printer is ready but nothing prints
Yes, there is a number for Epson printer technical support. Assuming you are in the US or Canada the number is on this web page: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=29081&prodoid=37368464 If you?re interested in troubleshooting this further let us know and please don?t forget to rate this posting.
Jan 24, 2007 | Epson Stylus Photo R200 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
